I have built a few guitar tube amps from kits and wanted to get a basic tube Stereo going. so I just got this Sylvania 45C14M on Ebay for $50 to tinker with. I won't have it for a week or so but I would like to start gathering information as soon as possible.
according to the seller, it works as is and the tubes test strong so I shouldn't have to do much
( but we will see)
The thing I will need help with is adding a bypass for the Phono Input/EQ for a Mp3 line in. I was thinking about using a rotary switch so that I could still use the phono input for a turntable. would this even be possible? If not I will just use LP's only, no big deal. I am trying to find Schematics and diagrams that I don't have to pay for but so far i have had no luck.
if anyone has some experience with this amplifier I would appreciate any advice you can provide.
( but we will see)
I got a copy of the PhotoFact Manual, for SYLVANIA 45C13 / 45C14 (#508) for $6 so I will upload the schematic page when I get it. maybe someone can guide me a bit through the process. I can read schematics as far as whats there and where its going, but as to why and what it does I am a little lost still.
I have the schematic now
http://img215.imageshack.us/img215/5774/45c13page2image0001web.jpg
http://img26.imageshack.us/img26/6083/45c13page4image0001web.jpg
I have a few questions.
can anyone tell me if this has the RIAA cruve circuit in it?
I know what the rumble filter does and i think K3+K6 is just the EQ circuit between preamp and power amp. but what is the K1+K4 tone comp ? is that tone compensator as in the RIAA curve circuit ?
also based on the schematic would it be safe to run an mp3 player into the inputs,
or would that be to much input gain?
and last one, would the rumble filter affect MP3 playback sound much?
If I can just use it as is without the circuit altering the input signal much I will just leave it alone
again I would appreciate any advice.
Very interesting! A sum and difference amplifier - I've never seen one before, and I thought I'd seen everything. The two inputs are not left and right, but rather vertical and horizontal outputs from the phono cartridge.
To use this with conventional left and right stereo inputs will require either changes to the amplifier or a sum and difference matrix ahead of it. Personally, I'd be tempted to change to two (identical) conventional output transformers.
All good fortune,
Chris
All good fortune,
Chris
All good fortune,
Chris
If you don't mind can you explain this further? I have never heard of this before,
I thought it was just 2 parallel mono amps in there.
The amplifier has a loudness-compensating volume control (K1) and a fixed equalization circuit (K2).
Before changing anything in the amplifier, I suggest that you connect your MP3 player and listen for a few days.
so far I have had it hooked up to a set of cheap 8 ohm bookshelf speakers here at work and it sounded fine. I did have the mp3 player at low volume though. also there is no hum at all when idle, I expected some ac hum.
also if you dont mind can you explain loudness-compensating volume control and a fixed equalization circuit ? I would appreciate it. like i said this is new territory for me
That's the way every other amp you'll ever see is made, but this one's unique. Look at the output transformers and you'll see why. This amp is made for the single purpose of use with a special (unique except for Decca, I think) stereo phono cartridge with sum (horizontal) and difference (vertical) outputs. At the amp's outputs, they're matrixed into left and right channels. I'm surprised that there's much stereo difference to the outputs. Are they in phase?
All good fortune,
Chris
All good fortune,
Chris
I wasn't able to do much testing here at work, I only had a 30 minute lunch break. but when I get home I will test it more. It didn't sound like L&R are out of sync, if they are its so little i didn't notice. I will play some tracks with L/R panning later to see what happens. This reveals how little i know about Phonographs
also on another note based on the schematic what kind of head would you recommend I use in a phonograph that will work well with this circuit?
These "matrix" stereo amps had a brief run, didn't last long - will only work with out-of-phase inputs, so aren't usable with a tape input for instance... Maybe they were planning to eliminate some parts in the FM multiplex decoder! But I don't think they even lasted until FM stereo started.
Here's an article about the principle: http://www.audiofaidate.org/it/articoli/Crowhurst_matrix.pdf
I would replace the output transformers and use it as a stereo single-ended amplifier.
Thats what I would like to use it for, but i wouldn't know where to start as far as what transformers I should use. I would need a guiding hand for that and this being so unusual is it valuable and should I just leave it alone? it seems to work just fine for what it is
so far so good. I played several genera's of music for a few hours and everything sounds fantastic through some MB quart SAT50's I had. the left and right pan like normal. also running a single input it supply's sound to that side only, so its definitely in stereo. I did notice at high volumes there is a slight cross talk with one side unhooked, but its very faint. and the volume is tricky, each layer on the dual pot has a slightly different taper so I have to level the channels out with each adjustment. the only negative is, the power transformer gets a bit warmer than i think it should. but only hot enough I cant touch it for more than 5 seconds.
and I think am going to get a high pass filter for the input line, I am getting a bit of distortion from the low end with some genera"s of music. I think I might roll the lows off at 150hz and use a sub woofer to fill in. those mb quart bookshelf speakers are super clear but the 4" drivers don't handle bass very well
I like it as is, but I still have that strong urge to improve it I think changing the output transformers for total channel separation sounds nice and i would like to change the volume for both channels to one control. but I think I will need matching OT's to do that :/
I would appreciate opinions and guidance on the transformers and volume
and thanks for all the info guys.
still working like a champ so I think I will just leave it as is for a while.
I plan on getting a pair of fostex FE126En drivers for it, but I still cannot decide on a box design. serously thinking about trying one of the Frugel-Horn Mk3 flat-paks or try to build a "iBIBK" box.
- Tubes / Valves
- Sylvania 45C14M advice
