bias capacitor
bias capacitor
Old 12th June 2012, 09:07 PM   #1
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
Default bias capacitor
This has probably been asked before but I did a search and nothing seemed related so.....
can somebody advise what's the best type of capacitor in the C? position. I think I need to trap the - dc content but not affect the ac load...am I looking at this the right way?...If I use an electrolytic backwards then aren't I putting it in the wrong way round with respect to the signal?
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 12th June 2012, 09:14 PM   #2
DF96 is offline DF96  England
C will have little signal voltage across it, so it can't do much harm. Given the probable high impedances it need not be an electrolytic, although there is no reason why it should not be.
bias capacitorHide this!Advertise here!
Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted tiefbassuebertr Pass Labs 22 8th May 2018 12:54 PM
Capacitor Throwing off Bias Point Mark245 Solid State 2 2nd September 2009 11:01 AM
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
bias capacitor lt cdr data Solid State 4 16th November 2006 01:04 PM
