Schematic to a friend
Old 12th June 2012, 07:57 PM   #1
Hojvaelde is offline Hojvaelde  Denmark
Question Schematic to a friend
Hello Friends
I've made a schematic for a friend, and now I want the specialists to comment on the schematic before we start the soldering iron.
Thank you in advance
You must not look at the pin numbers on the schematic. They do not fit.
Benny
Denmark
Old 12th June 2012, 08:16 PM   #2
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Be sure to bypass V5's g2 (screen) to ground or cathode. Looks good. Pentode output stages can often benefit from a Zobel across the speaker output terminals - cheap 'n cheerful.
All good fortune,
Chris
Old 13th June 2012, 08:13 AM   #3
costis_n is offline costis_n  Greece
Just make sure that G2 current is always enough to keep the 39V Zener in the linear range. Maybe you need a lower wattage Zener.
Old 13th June 2012, 07:58 PM   #4
Globulator is offline Globulator  United Kingdom
Globulator's Avatar
Note that these are my opinions and other people may disagree:
I'd do the NFB differently - run a 47uF capacitor from the 6BG6 anode through a 47K resistor into the top of R2, delete R3 and C1.
You may need to tweak values slightly to taste and gain.
I'm assuming this is a power amp - if integrated I'd add another triode at the front end like an ECC88.
Use a follower for D3 too if possible.
No idea about the PSU - didn't look at that.
Schematic to a friendHide this!Advertise here!
friend needs help goodsguy Chip Amps 1 16th September 2010 06:27 PM
Hello. Looking for a friend. acratus Introductions 1 14th October 2008 09:48 PM
Need help finding a phono schematic for a conversion for a friend Gunny Instruments and Amps 2 8th January 2007 02:59 AM
A North European friend asked me to show you this schematic. destroyer X Solid State 11 8th October 2004 06:12 AM
