Source for transformer parts?
Old 12th June 2012, 01:53 AM   #1
ChrisA is offline ChrisA  United States
Default Source for transformer parts?
I'll ask this here in the tubes section because that is what I intend to use this with..
Anyone know where I can buy transformer parts such as E/I cores, insulation paper and end bells. I'd like to learn how to design audio transformers. I don't expect to save money and yes, I know it is not easy. This is for my own education and amusement. The wire is easy to find. I've been reading about output transformer design for some time and want to try some ideas.
I know I can salvage old transformers but I'm looking for a source that sells a wide selection of new parts.
That said I've found a company called "Alpha Core" can make "C-Cores" that might be used for audio (maybe)
Old 12th June 2012, 03:11 AM   #2
lakeside is offline lakeside  United States
lakeside's Avatar
Here is a link for laminations. I'm not sure what there min order is however.
Thomas and Skinner - Transformer Laminations
Here is a source for end bells and other components
Transformer Components
Hope this helps
~Mike
Old 12th June 2012, 05:21 AM   #3
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i suggest you touch bases with BudP and cerrem, they are both members here and i know they can help you out....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 12th June 2012, 10:00 AM   #4
pieter t is offline pieter t  Netherlands
Stick with c-cores; the alpha cores are audio grade.
C-cores are much more practical to work with than EI laminates (especially when applying air gaps), and generally superior to EI cores for audio transformers.
McIntosh was aware of this long time ago (and so do the better quality transformer manufacturers nowadays).
Old 12th June 2012, 10:22 AM   #5
TonyTecson's Avatar
Alpha core is it....they sell retail.....if only i could get my hands on those.....
Source for transformer parts?Hide this!Advertise here!
Overlooked source of parts MRehorst Parts 10 10th January 2013 12:04 AM
New Source for Parts embrown057 Parts 0 17th May 2011 07:58 PM
Carver parts source????? THUMP LUMP Digital Source 3 15th October 2010 11:58 PM
Need Source for Behringer Parts W3KQ Instruments and Amps 1 3rd July 2009 05:22 AM
Help with parts source please Mark777 Parts 1 10th December 2005 04:14 AM
Copyright ©1999-2017 diyAudio
