Anybody seen this one? - diyAudio
Old 12th October 2003, 04:32 AM   #1
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Default Anybody seen this one?
Well, here's a jab into the knowledge of the tube guys!
I am pretty sure that this picture is of a tube, but correct me if I'm mistaken.
I found this nifty little device in a bin of diodes at the school electronics shop. I cleaned it up a bit and found that it's made by General Electric. It has some numbers on it: GL-6299 which is probably the type. There's another in kind of lopsided print: 8854 which seems like it would be a serial number of some sort.
Has anybody seen this device? Can you verify whether or not it's a tube or what type it is if so?
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 12th October 2003, 04:43 AM   #2
zzz is offline zzz  Canada
Send a message via ICQ to zzz
http://hereford.ampr.org/cgi-bin/tube?tube=6299
oui?
Old 12th October 2003, 04:51 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Aww I just typed a reply and then stupid Acrobat plugin crashed IE. Anyway I was gonna say:
Looks like a 'lighthouse', or planar triode.. lesse if ol' Frankie has any data... Ah:
http://www.mif.pg.gda.pl/homepages/f...149/6/6299.pdf
Doesn't look good for much besides its intended purpose...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 12th October 2003, 05:00 AM   #4
li_gangyi's Avatar
This thing looks like a mini Klystron or a high-frequency valve...not so sure though...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 12th October 2003, 06:00 AM   #5
Duo's Avatar
Quite interesting. When I found this I had no clue what it was, but by looking at it closely, I found that there were enough pins for it at least to be a triode and the it seemed to be shaped like some sort of tube.
I guess I'm good at observation?
Well, good to know what it is so I can use it in my next project.
It will make an excellent tube in a UHF radio for a gainstage or oscillator.
Old 12th October 2003, 06:15 AM   #6
li_gangyi's Avatar
so what are u planning to do witn it?? seems preety hard to break in that package...
Old 12th October 2003, 07:04 AM   #7
316a is offline 316a  England
316a's Avatar
Default Funny triode
Good luck finding the sockets ! If you do try to use this thing remember that the contacts will be exposed if mounted on top of the chassis . The problem with UHF valves is that they seem to like to oscillate on their own , may be problematic trying to implement , not just for the socket issue . Curves look nice though !
316a
Old 12th October 2003, 10:07 AM   #8
Duo's Avatar
It'll be no problem. I'm good at fiddling with tubes so I'll make it a socket or find one somewhere.
I'll build a circuit for it and if it doesn't work properly, I can always modify it.
It's interesting just to see something like that in operation, would be a cool tube to see on the top of an open chassis.
Old 12th October 2003, 10:03 PM   #9
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
..snip would be a cool tube to see on the top of an open chassis.
It would indeed look very strange. That valve is a disc seal triode designed to be mounted in a cavity. In normal service, it'd never be seen.
Bear in mind that this class of device relies on conduction cooling through the clamps that fit the rings, but in this case, being only 2W, it may not be a problem.
Enjoy
Old 12th October 2003, 11:53 PM   #10
diyAudio Senior Member
fdegrove's Avatar
Enjoy
...Your latest oscillator?
Planars are definitely the worst kind of female to work with...
Like most members of the opposite sex they look cute enough though...
Frank
Copyright 1999-2017 diyAudio
