Why a follower in a parafeed triodeamp?
Old 13th June 2012, 08:39 PM   #21
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
Yes I am confused as to the results as well. I'm not totally sure if being #1 means that harmonics are higher or lower although I think it means lower?
Old 14th June 2012, 07:00 PM   #22
revintage is offline revintage
Hey spread,
So you where unable to read post #9?
If anyone wonders about "MJK-style parafeeds with Schaded 6L6" this is a parafeed AC-coupled version of this:
http://www.diyaudio.com/forums/tubes...ml#post2204502
Old 14th June 2012, 07:57 PM   #23
So you have corrected the errors or haven't? Do you have a result or not? If so, what is it?
EDIT: I really do want to know what the result is.
Old 15th June 2012, 05:59 AM   #24
Read again. Posts 10&13&19. Might come back when the SEPTOR(its in the linked thread) is rebuilt for MOSFET mu-follower, not AT. If going for mu-follower, forget tubes, they have to low gain/gm to reduce un even harmonics.
As MJKs 6L6 hybrid have a little to much odd H it will probably be helped by a follower. Will come back with a schematic of how I think it should be done. and what the indications are.
Old 15th June 2012, 06:24 AM   #25
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Lars, it is very similar to my Nirvana. I can't tell now more than it is the right way to go.
The Devil is not so terrible as his math model is!
Old 15th June 2012, 06:29 PM   #26
Globulator is offline Globulator  United Kingdom
Globulator's Avatar
Would it be possible to have an simple version of this for dummies please?
Out of the initial 3 circuits posted, which was the best and which was the worst, and what type of circuit should we be preferring?
TIA./
Why a follower in a parafeed triodeamp?Hide this!Advertise here!
Hot follower/cool follower webercarbmann Solid State 13 2nd November 2010 02:23 PM
Need help with DC follower/peak follower HELP! gain wire Parts 4 8th July 2008 03:32 PM
to parafeed or not to parafeed that is the question nhuwar Tubes / Valves 63 28th February 2007 12:29 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
Parafeed Brett Tubes / Valves 14 7th April 2003 12:53 PM
Copyright ©1999-2017 diyAudio
