6DX8/ECL84/6F3P Baby Huey - diyAudio
Old 7th June 2012, 03:57 AM   #1
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Default 6DX8/ECL84/6F3P Baby Huey
I've posted previously in the "EL84 Baby Huey" thread that I thought the 6DX8 aka ECL84 aka 6F3P would make a nice Baby Huey.
I figured I'd start a new thread as I build this amp, based on the triode/pentode combo video device (which is also listed by Miniwatt as an audio amp).
I've been simulating it off and on for a while, and finally got a chance to pull out the tube-lab and breadboard something.
If I flog it, I can get 14W out with slight red plate on one tube. I could probably hand select tubes to run at 14W.
Dialing it back I get 10W without problems at 66% red plate dissipation (still greater than spec).
I switched to a speaker with You Tube source from a computer, and adjusted the input LTP bias by ear and it sounds pretty good.
I'm running a GXPP10-8-10K.
300V B+
26mA bias current, fixed bias.
Old 7th June 2012, 06:36 AM   #2
hidnplayr's Avatar
Please, do keep us posted, you got at least my attention
Do you have the output pentodes connected in UL or plain pentode?
Real tubes have top-caps
Old 7th June 2012, 11:33 AM   #3
Soonerorlater's Avatar
+1
When white moths were on the wing,
moth-like stars were flickering out,
Old 7th June 2012, 11:34 AM   #4
Quite an interesting tube, 'cause it's triode is somewhere between 6SL7 and 12AT7. And cheap also: Recently I've bought a bunch of them at €2.50/pc, made by Mullard..
But 14 watts anode dissipation when the maximum dissipation is 4 watts? Wow!
Best regards!
Old 7th June 2012, 12:28 PM   #5
TheGimp's Avatar
Outputs are wired UL Mode currently.
The 14 Watts was the output at 1KHz with the plate of one output tube a dull orange that could hardly be seen with the lights on. It was evident with the lights off.
No signal dissipation was about 12W. From past testing I've done, I believe 8W plate dissipation is going to be reasonable. I'm currently running 7.8W (300V B+ at 26mA bias current).
The 6DX8 is available from ESRC in the US for $1.00ea in qty 10. The ones I'm using are Raytheon, but I think I have another brand as well as the 6F3P.
Old 7th June 2012, 02:43 PM   #6
TheGimp's Avatar
In case anyone finds this thread later on, here is the original Baby Huey thread which was the impetus for this design:
EL84 Amp - Baby Huey
Old 7th June 2012, 03:30 PM   #7
300V B+
That means a plate-to-plate load of 20 kOhms with UL taps at 63%?
Best regards!
Old 7th June 2012, 04:22 PM   #8
TheGimp's Avatar
The transformer is rated at 10W, 10K plate to plate , 40% UL taps single 8 Ohm output.
Old 7th June 2012, 04:44 PM   #9
Cookj is offline Cookj  Belgium
My understanding-
6F3P is equivalent to ECL82,
6F4P is equivalent to ECL84
6F5P is equivalent to ECL85.
John
Old 7th June 2012, 05:25 PM   #10
TheGimp's Avatar
You are correct. I confused 6F3P and 6F4P. The title should read
6DX8/ECL84/6F4P Baby Huey
If an admin would change it, it might be helpful to someone in the future.
Baby Huey components WindChill Tubes / Valves 15 12th March 2010 06:39 PM
Could this become a Baby Huey killer ? Jaap Tubes / Valves 240 7th May 2009 07:09 PM
Copyright 1999-2017 diyAudio
