Need help on RIAA - Page 3 - diyAudio
Old 6th June 2012, 05:02 PM   #21
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Can somebody explain to a non-musician boy (me), which makes the sound difference between types and or brands of components in audio? I believe that there is some psychosis about it.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 6th June 2012, 05:09 PM   #22
SY's Avatar
Yes, there is much of that. There are, however, some basic engineering issues in selecting components- for tube guys, Morgan Jones covers the stuff in gory detail in his book. Rule of thumb- components specifically marketed to audiophiles are almost invariably grossly marked up and no better than reputable industrial brands. Quite a few "audiophile" components are significantly inferior.
If you can't get a component from a mainstream supplier like Newark or Mouser or Digikey, that's a strong indication that you're paying for psychosis and prestige rather than performance. You don't find special audiophile grade resistors in a radio telescope, a CAT scanner, or a neutron detector.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th June 2012, 05:18 PM   #23
SY: I agree. I have made tenths of electronic designs, from a simple audio amp to a solar cell battery charger regulator using two SMPSīs with current sharing and with both operating 180 deg out of phase (from who Iīm powering my ham radio stuff including a packet radio modem and 12V low power fluorescent lamps), and I could never see differences so small. Yes, I can see the performance difference between, say, an audio 85deg cap in a SMPS, and a 105deg Nichicon, by example (measuring ESR, ESL, durability, etc.). But, I canīt understand which difference may be between a coupling cap of polyester, polypropylene, paper, oil, etc. in terms of "sound effects".
Old 6th June 2012, 05:21 PM   #24
The better the design, the less sonic influence of "audiophile" components.
Old 6th June 2012, 05:29 PM   #25
And I can add: IMHO, if certain electronic device work fine ONLY with certain brands or type of components (Except specific parts like a processor, ADC or DAC., some tubes, or so), is definitively a BAD DESIGN for me.
Old 7th June 2012, 01:12 AM   #26
Originally Posted by kevinkr View Post
I'd recommend good 1% tolerance 1/2W (RN60) metal films like Dale or PRP (Precision Resistive Products), for the eq caps polystyrene film and foil caps like the REL RT series. For coupling and bypass capacitors Russian FT-3 series comes to mind. Output cap probably a good polypropylene like the Clarity SA/ESA series or something from Janszen.. There are many choices, these are just some that have worked for me in the past, none are too expensive.
Alternately you could order parts from Michael Percy, and have them shipped to Vietnam by mail.. I've bought small quantities of parts from him for more than 24yrs now - highly recommended. Here: Michael Percy Audio Ordering Information Not sure about duty and the like however.
Many thanks, Kevin. I will check it out.
BTW, can you please kindly tell me more about the pros and cons of moving R25 before R17?
Thanks and regards
Andersen
Old 7th June 2012, 02:53 AM   #27
kevinkr's Avatar
Thanks and regards
Andersen
No cons really except that the combination should not exceed the rated maximum grid circuit resistance for the tube used.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 7th June 2012, 04:34 PM   #28
Smile Inverse RIAA Filter
Hi All,
We speak of 1% components, calculations and simulations to meet the Goal of the RIAA curve.
How do we DIYers measure the results for accuracy? How do we know that all that precision did what we hoped?
Back in the early posts Revintage recommended the use of the Hagerman Technology LLC: iRIAA Filter for Phonostage DIY Kit "Inverse RIAA Filter" to test the results. Using this method the results depend on the design and accuracy of the inverse filter.
To use an "Inverse RIAA Filter" for testing my assumption is that all the items, Device Under Test and inverse filter all plug into a PC based software program for output of the results.
The question; do any of the DIY affordable PC programs have a RIAA curve built into them for testing?
DT
Old 7th June 2012, 04:53 PM   #29
kevinkr's Avatar
Originally Posted by DualTriode View Post
Hi All,
<snip>
DT
As far as I know there aren't any affordable programs that have this feature, Audio Precision has provision for limit files that do this and can also do the inverse RIAA directly without an external network, but not what I would call affordable unfortunately.
I have two inverse networks, one used to be guaranteed +/-0.1dB (it's commercial and one of my former employers gave it to me when they stopped being interested in RIAA equalizers) - the other is home brew.
That said I usually do a response measurement and look at the overall response normalized to unity gain at 1kHz and compare a number of points on the curve with a set of tabular values. Works fairly well, but can be very tedious if you are looking at a lot of points.. The problem with the inverse network is that the response is the sum of both the errors in the inverse network and the pre-amplifier equalization, when you are getting into the 0.1dB range this is a huge problem.
I suspect that tenth dB accuracy (or at least verifying it) is going to be difficult to achieve in most PC based measurement setups, and no way to conveniently verify without precision external test equipment.
Old 7th June 2012, 06:51 PM   #30
gk7 is offline gk7
You can generate riaa wav test files with sox:
Error in D. Self-Riaa?
RIAA? Osvaldo de Banfield Solid State 2 21st December 2011 02:54 PM
RIAA help philipbarrett Tubes / Valves 4 22nd March 2005 01:55 PM
Just another RIAA...... Chris Analogue Source 26 8th June 2003 07:34 PM
Riaa........... Chris Everything Else 15 12th September 2001 02:31 PM
Copyright Đ1999-2017 diyAudio
