Need help on RIAA
Need help on RIAA
Old 7th June 2012, 07:13 PM   #31
Stephen R is offline Stephen R  England
Stephen R's Avatar
Based on the circuit in post 15 and a rough sim, I get R17=86k, R23=14.4k (12k+2.4k).
C1 is too small to feed an EQ so that should be 0.47u otherwise it may sound a bit bass shy; 1.5dB down @ 20Hz.
I like the coupling cap in the grid of the 2nd stage, then it can be 0.1u or smaller if the grid resistor is bigger than 470k. However that can make getting the EQ caps hard in 1% values. I like silver mica so not too hard to get 1% or better in high voltage types.
Also not sure if a 0.22u on the output is big enough. I'd use 0.47u to 1u. Depends what it's driving of course.
cheers,
Stephen
Old 8th June 2012, 01:49 AM   #32
Andersen is offline Andersen  Viet Nam
Based on the circuit on post #15, Zout of 6922 cascode = Ra // (mu+2)xRp = 22K // (33+2)x3K = 18,189 ~ 18K. As C7, C9 and R23 were calculated based on R1 at 100K, R17=100K - 18K = 82K.
Old 8th June 2012, 04:34 PM   #33
Stephen R's Avatar
The calcs most people make a simplistic at best as they very rarely cover most of the variables even the most obvious ones.
Part of the calcs most people miss is the varying load of the EQ esp at low frequencies that will affect the low end and most people forget about the coupling cap effects esp at low frequencies plus the grid load effects of the 2nd stage.
Lipshitz while a great starting point misses out all these real world variables. Also look at the assumptions Lipshitz makes for the output Z of the driver and the load ratio of the load. Valve circuits almost never meet these assumptions.
Hence the reason I use a sim. Sim the cct, buy the 1% parts, stick them in and presto, done. Unless some gross errors have been made, that should be the end of it.
cheers,
Stephen
Old 20th June 2012, 08:13 AM   #34
Default Cathode Follower
Hello again
I intend to add a cathode follower stage at output as shown in the attached schematic. Can you please kindly advise me if it's ok and if C14 can be removed and what the value of R should be?
Many thanks and regards
Andersen
Old 7th September 2012, 05:27 AM   #35
Default Final Result
Finally, I completed my phono pre-amp with the attached schematics and the actual RIAA curve. Great result, right?
Thanks, all for your help.
Old 28th April 2013, 05:25 PM   #36
GoranSk is offline GoranSk
Hello
Great RIAA curve but the attached schematic looks a little bit strange. C9 has a lager value than C7; I have never seen that before. Typing error ???
/GoranSk
Need help on RIAAHide this!Advertise here!
RIAA? Osvaldo de Banfield Solid State 2 21st December 2011 02:54 PM
RIAA help philipbarrett Tubes / Valves 4 22nd March 2005 01:55 PM
Just another RIAA...... Chris Analogue Source 26 8th June 2003 07:34 PM
Riaa........... Chris Everything Else 15 12th September 2001 02:31 PM
Copyright ©1999-2017 diyAudio
