Old 4th June 2012, 05:36 PM   #1
Default GU50 plate curves
does anyone of you know a source of GU50 plate curves at a screen voltage of 300 volts? Any sheet of LS50, EL152 and GU50 itselves that I know only shows curves for 250 v screen voltage.
Thanks in advance!
Old 4th June 2012, 08:14 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
If I remember right LS-50 datasheet contains curves with different G2 voltages, so it can be extrapolated approximately.
It has G3 as well. Adding +10-30V on it works similarly, without fear of frying G2.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 5th June 2012, 04:21 PM   #3
Hi Wavebourn,
the one that I know sadly doesn't feature plate curves referencing to 300 v screen. But the plate curves herein at pages 2 (top) and p3 (bottom) respectively, surprisingly differ much!
I've also had a look at the EL153 curves, mainly the same tube, but lacking the supressor grid, but also there's none for 300 v screen.
Best regards!
Old 5th June 2012, 07:03 PM   #4
Globulator's Avatar
The main problem I have with the GU50 datasheets is the Russian language. I guess Anodespannun is Max Anode voltage, but the rest is a bit of a mystery TBH - so I tend to build, measure, tweak - a bit like fumbling in the dark!
Compared to that the small signal stuff is easy
Old 5th June 2012, 07:49 PM   #5
I guess Anodenspannung is German and means anode/plate voltage !
Best regards!
Old 6th June 2012, 02:06 AM   #6
jazbo8's Avatar
Originally Posted by Kay Pirinha View Post
Hi Wavebourn,
Best regards!
I thought EL152 is the civilian version? See if this one make sense.
Jaz
Old 7th June 2012, 11:42 AM   #7
Thanks. I know this sheet. At page 9 we find suitable data for audio frequency amplification, but it doesn't show the requested plate curves @300v screen. Those at p.3 relate to 250 v screen.
Best regards!
Old 9th June 2012, 09:39 AM   #8
Check this thread:
Trying to make sense of the Sweet Peach
There's also some other threads on the GU50 with data, mostly supplied by Wavebourn, who's an expert.
Old 9th June 2012, 06:59 PM   #9
Best regards!
In all GU50 datasheets only 250V G2 operation is mentioned. So this means you have to extrapolate them (make them up )
Bilingual datasheet here. Seems like they wanted to make monies off potential enemy, too
http://tubedata.milbert.com/sheets/018/g/GU50.pdf
Old 9th June 2012, 07:17 PM   #10
Wavebourn's Avatar
PDF format did not exist during Cold War.
Home-Made Plate Curves Ardee Tubes / Valves 2 22nd March 2011 07:32 PM
15E and plate curves lochness Tubes / Valves 5 4th November 2007 03:41 AM
basic question on plate curves Craig405 Tubes / Valves 14 27th October 2006 08:56 PM
please explain plate curves frank2395 Tubes / Valves 4 19th May 2005 12:03 AM
plate characteristic curves help jlsem Tubes / Valves 1 15th July 2003 07:50 AM
Copyright ©1999-2013 diyAudio
