Help with GZ34
Help with GZ34
Old 4th June 2012, 04:11 PM   #11
daghettoalbanian is offline daghettoalbanian
Actually i found the schematic thank you for the help! I will try it later today and see if the rectifier works.
Old 4th June 2012, 04:16 PM   #12
kevinkr's Avatar
Help with GZ34
Before proceeding further can you confirm that you have a separate 5V filament winding for the GZ34? If you don't you will need to get a 5V filament transformer - you cannot have rectified B+ on the existing 6.3V filament winding safely.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 4th June 2012, 05:32 PM   #13
And im not sure if it is supplying 5 volts or higher, I cannot find a datasheet for the power transformer of the blues junior, I have looked everywhere, I have found the secondary, and the filament voltages, but am unable to find what the brown wire voltages are
Help with GZ34Hide this!Advertise here!
Why two GZ34 in this schematic? mfaughn Tubes / Valves 3 20th June 2011 09:27 PM
Toughness of GZ34? flyinglemur Power Supplies 0 8th March 2008 09:14 PM
GZ34 and temperature rossdt Tubes / Valves 2 26th October 2006 09:04 PM
Got sparks in my GZ34! HeadSh0T Tubes / Valves 29 19th March 2004 07:49 PM
