circuit idea
circuit idea
Old 3rd June 2012, 08:17 AM   #1
Jehan is offline Jehan  Indonesia
Jehan's Avatar
Default circuit idea
this circuit will work as single ended or push pull? If there's any typo, please tell me.
Old 3rd June 2012, 12:02 PM   #2
Globulator is offline Globulator  United Kingdom
Globulator's Avatar
The circuit seems to be on its side for me so very difficult to read, also I think the component values will be needed to work out what it does!
Old 3rd June 2012, 01:03 PM   #3
12E1 is offline 12E1  United Kingdom
12E1's Avatar
I can read it sideways, no problem - but the component ratios make a big difference (absolute values not necessary). For example, it looks a bit like a long-tailed-pair with a triode loading the second half, but depending on the values the first triode might be part of a LTP with gain, or a phase splitter with gain approximately 1. The RC network looks a bit like an Aikido noise reduction scheme, in the style of Broskie.
Old 5th June 2012, 10:32 AM   #4
DF96 is offline DF96  England
The two output valves appear to be opposing each other - count up the phase inversions from input to output via both paths. This is not single ended or push-pull - it is push-push.
Also, with no glass the vacuum may escape.
Whether it will work would depend on what it is intended to do. It will certainly consume electricity and heat a room.
Old 5th June 2012, 03:43 PM   #5
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Could be fixed up maybe. Take the resistor going to ground at the bottom and connect the grounded end to the cathode of the first stage, instead of to ground. Remove the wire from the 1st cathode to the 2nd cathode, connect the 2nd (bottom) cathode to ground thru a cap bypassed resistor for biasing. Make the plate resistor of the 1st (top) tube about Mu times (use Mu of 2nd tube, bottom) the cathode resistor to ground there, to proportion the grid drives. (Needs to take into account the V divider effect of the string of resistors at the bottom yet.) Presumeably an Aikdo like voltage divider at the bottom, will need adjusting to get the right hum cancelling on the bottom grid. Simulate, to see if this is all working correctly. (PSRR will likely depend on signal level without some further fixes.)
Put glass around the tubes before all the vacuum escapes.
Old 5th June 2012, 04:23 PM   #6
Fenris is offline Fenris  United States
Looks like a Broskie CCDA with a bit of Aikido thrown in:
CCDA: constant-current-draw amplifier
It should provide some positive feedback and hence some additional second order distortion. I used a similar front end on a guitar amp I built except with a potentiometer in place of the first tube's cathode resistor. The wiper connected to the cathode of the second stage and allowed varying amounts of positive feedback. It makes a nice colored sound, but loses accuracy.
Listen to the music through the stereo, not the stereo through the music.
Old 5th June 2012, 04:55 PM   #7
jrenkin is offline jrenkin  United States
I just have to say, a vacuum can't "escape". The lack of glass will let the air in. Not to mention dust, at least in my house, and that couldn't be good.
Old 5th June 2012, 05:09 PM   #8
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
circuit idea
It looks like a cathode follower loaded on counter - modulated CCS, with additional positive feedback. Can be called either PP, or SE. I called my Tower output stage that used similar principle SE.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 5th June 2012, 05:22 PM   #9
Except the "counter modulated" CCS is fighting the cathode follower here, instead of assisting it (check phase inversions as DF96 suggested).
Fenris's suggestion of the Broskie CCDA positive feedback may be what is intended here. Interesting, in that the added "CCS" tube on the bottom of the output follower puts the positive feedback thru a 1/Mu function (versus output V), so may largely remove the feedback loop distortion problem (Mu1 * 1/Mu2). Curious circuit. Doesn't correct the distortion of the input tube (to the output), but may prevent the positive feedback from making it worse.
Someone needs to rotate this image to prevent viewer headaches:
Old 10th June 2012, 11:23 AM   #10
Jehan's Avatar
Sorry for the glassless triode in the schematic. My goal is to create an aikido-like amplifier with the bottom triode work as grounded grid, not grounded cathode, any idea?
circuit ideaHide this!Advertise here!
Weird idea: PC-based AM carrier circuit radio Firepowerforfreedom PC Based 10 24th April 2011 09:11 PM
2way Circuit Breaker instead of melting fuse inside amp - a good idea? Lee Knatta Solid State 5 30th January 2011 06:41 PM
I think I have a neat, simple and easily implemented idea for a soft start circuit hifinerd Solid State 54 8th October 2010 01:05 PM
idea about 200w circuit khodeir Solid State 9 4th November 2009 06:22 PM
Idea: subwoofer protection circuit Datoyminaytah Subwoofers 9 2nd September 2004 05:19 PM
