Bias probes/Am I getting true readings - diyAudio
Old 3rd June 2012, 01:26 AM   #1
krisjay is offline krisjay  United States
Default Bias probes/Am I getting true readings
Hi all, I went ahead and bought a couple of the bias probes(they sit in the tube socket, then the tube sits in the probe socket) to use on a tube amp I have, the question I have is, am I getting true readings using a probe or is it skewed a little one way or the other, thanks.
Old 3rd June 2012, 02:51 AM   #2
HollowState's Avatar
Whether the bias probe uses a 1 ohm shunt resistor or inserts your multimeter into the tube's cathode, the result is the same from a technical point of view. Any resistance introduced into the cathode circuit will affect tube current by lowering it a tiny bit. (I don't think any of these "probes" connect to the tube's grid.)
However, these resistances are very small and for all practical purposes can be considered negligible. So the accuracy you get will depend on the accuracy of any socket resistor (if used) and/or your meter. But in the overall scheme of things, a couple of milliamps either way isn't that critical and is close enough for audio.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Mikael‑Abdellah‑SE‑KT88 Bias & Voltage readings Help? bigaudioscotto Tubes / Valves 49 7th July 2012 11:44 AM
Favorite readings. Gyuri The Lounge 4 21st March 2011 05:01 PM
scope readings east electronics Solid State 27 6th March 2009 12:08 PM
DIY Readings... Remedial Instruments and Amps 6 30th June 2004 01:00 AM
diode readings sriegel Solid State 2 21st January 2002 10:55 PM
Copyright 1999-2017 diyAudio
