How to measure output power - Page 2 - diyAudio
Old 2nd June 2012, 03:23 PM   #11
Frank Berry's Avatar
I have an idea for you. Please send me a private message and include your email address so that I can reply.
Frank
Old 2nd June 2012, 05:27 PM   #12
sofaspud's Avatar
Connect your voltmeter across the speaker. Play your test audio. Measure the RMS volts on the speaker. Compute the power using P = E^2/R where R is the speaker impedance.
A 400Hz tone would be much better to use. If you can't obtain one, maybe an audio editor like Goldwave could be used to "stretch" your 1kHz sinewave to 400Hz.
This isn't precision, but should give a useful rough measurement.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 2nd June 2012, 06:03 PM   #13
EddieRich's Avatar
@ Frank
Thanks for the mp3 test tone. I'm going to use that and some others at various frequencies and use sofaspud's method to get a rough approximation.
@sofaspud
thanks for reminding me of the math. I always forget the E^2/R versions of the power formula.
Old 2nd June 2012, 10:15 PM   #14
FullRangeMan's Avatar
Originally Posted by Original Burnedfingers View Post
How do you figure this? Bias x B+ x Output Transformer=output Watts
The Bias & B+ are informed by the amp datasheet or service manual.
Example in a big Triode amp:
0.80mA x 900V x Transformer= output Watts
The transformer value is a Primary/Secondary ratio I unknow.
Some expert would help??
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 5th June 2012, 10:37 AM   #15
DF96 is offline DF96  England
For a perfect single-ended output stage, maximum output power is half of (quiescent current x supply voltage). For a real SE stage it is a bit less than this. The transformer ratio is not relevant to this calculation, as all it does is transform impedance.
Old 5th June 2012, 04:32 PM   #16
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by EddieRich View Post
Thank you for the answers. Unfortunately, I don't have distortion analyzers, or even a scope. I was hoping it could be done with a multimeter. I'm not looking for exact, precise numbers. I just to want to see if I'm in the ballpark.
You obviously have a computer... That computer has a sound card. It may not be the best quality equipment, but it's generally good enough. Use that along with the free or demo spectrum analyzer and o'scope software around and you have a distortion analyzer and an oscilloscope.
Be careful with the sound card, though. They tend to have max input voltages on the order of 5 V, so you may have to build a 10:1 voltage divider so you don't fry the sound card when measuring the amp output.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 6th June 2012, 09:49 PM   #17
OK, Very thanks for your nice reply, I appreciate it.
Best Regards
Old 7th June 2012, 01:32 PM   #18
Don't use the speaker for the load as you will have no idea as to what impedance it is.
Here's the simple answer:-
Use an 8.2R, 5W resitor as the load. Get your speaker and add a 330R resitor in series with it.
Now put the speaker/330R resistor combination in parallel with the 8.2R resistor.
The amp will now see an 8R load.
You can then put your meter across the output the amp and wind up the sine wave until you can hear it starting to distort (it will be fairly quiet), back off the level so it no longer distorts and read the meter (should be RMS volts).
You now have the RMS Volts and the correct load impedance so you can work out the power.
Henry
Old 7th June 2012, 02:10 PM   #19
sofaspud's Avatar
I believe the speaker impedance is 8 ohms. The question is, at what frequency? I'm also assuming 400Hz is the frequency used by the speaker manufacturer.
A suitable multimeter can give a "ballpark" distortion indication: Take a peak reading of the sine wave. Compare that with an RMS reading of the same sine wave. The latter should be 0.707 of the former. If it isn't, that's a good sign that the signal is clipping.
How to measure output transformer? Burnedfingers Tubes / Valves 42 15th June 2016 11:51 AM
How to measure transformer output CST10 Power Supplies 3 4th September 2011 06:32 AM
How to measure amp power output hernanstafe Parts 2 16th February 2007 01:27 AM
How can I measure dB output? Duo Multi-Way 30 24th April 2003 02:53 PM
How to measure digital output of CD. protos Digital Source 0 5th March 2003 11:50 AM
Copyright 1999-2017 diyAudio
