diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Looking for a fairly simple Hi gain tube pre amp project (http://www.diyaudio.com/forums/tubes-valves/213640-looking-fairly-simple-hi-gain-tube-pre-amp-project.html)
jackasspenguin 31st May 2012 04:00 PM
I'm interested in a schematic and or complete plans to build a 12ax7 hi gain tube pre amp for guitar applications. My intentions are to stick something into a small chassis and use as a foot controlled pedal of sorts to drive my Fender Super Reverb made circa 67. I may perhaps build two of them to have a 2 channel clean, and dirty output.
This is my first post here. Hope to enjoy the site!
Cheers!
Johnny
Merlinb 31st May 2012 04:39 PM
Take a look at the projects at AX84.com - The Cooperative Tube Guitar Amp Project
Alvis 31st May 2012 04:54 PM
Here's a "Soldano" preamp. Those AX84's don't quite get there.
Soldano Preamp : DIY Fever – Building my own guitars, amps and pedals
Alvis 31st May 2012 04:56 PM
Originally Posted by Merlinb (http://www.diyaudio.com/forums/showthread.php?p=3043822#post3043822)
lol, are you the "Merlin" mentioned in my link?
SY 31st May 2012 05:00 PM
Although he was too modest to mention it, MerlinB is the author of a book that will answer your question and many more. Highly recommended.
http://www.amazon.com/Designing-Tube...8483622&sr=8-1
Alvis 31st May 2012 05:21 PM
Too cool.
There are lot's of sound clips for the AX84 HO online and a few sound clips of the Soldano at the bottom of the page I linked.
You can get a pretty good idea to the differences in tone by the videos.
Dragondreams 1st June 2012 07:24 AM
The Real McTube (Fred Nachbaur) might be of interest. I've built a couple of these as pre-amp boosters into my valve guitar amps. They sound great, as well as being a relatively simple build (with a lot of scope for tweaking).
The Real McTube II
Keysy 7th December 2012 03:14 AM
I am no expert and it seems a bit crazy to question anything in the Real McTube but why does he bother to rectify the heater circuit? Can't I just run one secondary of the 12V AC to pin 4 and the other to pin 5/ground to supply the heater?
Dragondreams 7th December 2012 08:04 AM
Hum. ;)
On Fred's page he actually states:
"This results in a significant reduction of AC hum as compared to the original "Real McTube", which used AC to directly heat the tube's filaments."
DF96 7th December 2012 09:41 AM
Instruments & Amps???
Copyright 1999-2017 diyAudio
