good tube service tech in Los Angeles? good tube service tech in Los Angeles? - diyAudio
Old 30th May 2012, 09:41 PM   #1
cuibono is offline cuibono  United States
cuibono's Avatar
Default good tube service tech in Los Angeles?
I'm looking for someone with some pretty solid tube gear repair chops.
I have two pieces of gear I'm looking to have fixed. I repair electronics, but these two are beyond me. The first is a 50's era tube amp, fairly simple, but there is no schematic. It has a bit of hum on the output. I've replaced the caps, but the problem persists. I'm guessing a fried resistor or film cap in the psu somewhere.
The second piece of gear is a Gates Limiter, SA-39, also from the 50s. I have a schematic for it, and it passes signal, but isn't working properly. I think the compressor circuitry needs to be balanced.
Anyway, if you have any recommendations, let me know. Ideally I'd like to find some retired tube tech that can take on occasional work. The only requirement is that they be in Los Angeles county. My email is peglegpatrick ATT gmail DTT com.
Old 31st May 2012, 12:09 AM   #2
bear is offline bear
expert in tautology
bear's Avatar
If you do not find anyone, PM me and I can ask a pro studio/tech group that I participate in. They will have no trouble with ur Gates or the tube amp...
The guy I would send you to first just left LA to come back to NYC...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 31st May 2012, 01:05 AM   #3
Wavebourn is online now Wavebourn  United States
Wavebourn's Avatar
I would recommend you to contact Geoff, he should know local guys who deal with tube equipment in your area: Pro Audio Recording Equipment | Aurora Audio
If your compressor needs repair/adjustment, your amp needs upgrade: it was common for that time to have poor according to modern expectations filtration, and ground loops were common. Capacitance was bulky and expensive, voltage regulators were very expensive.
The Devil is not so terrible as his math model is!
Old 16th July 2012, 10:17 PM   #4
cuibono's Avatar
I've talked with Geoff before - he is a great guy. Unfortunately, he didn't have anyone to recommend.
So if anyone knows any retired tube techs in Los Angeles, please let me know!
Thanks!
Old 16th July 2012, 10:53 PM   #5
Apex Jr is offline Apex Jr  United States
I sold to Charlie Bolois of Vertigo Recording Services in North Hollywood
some 6386 tubes for a repair of a Fairchild 660 compressor so I would
assume he is willing to repair tube equipment.
Old 16th July 2012, 11:27 PM   #6
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
speaking of LA area repair techs. im curious to know about any LA area techs/shops that specialize in high end home audio gear or pro audio equipment??
It's not about what you can BUY...It's about what you can BUILD!
Old 17th July 2012, 02:02 AM   #7
I would suggest Howard at the Audio Specialist on Ventura Blvd
in Studio City. Both a Tech and sells Audio Gear.
good tube service tech in Los Angeles?Hide this!Advertise here!
Los Angeles no gas Tubes / Valves 9 10th September 2010 11:20 PM
Need DIY help in Los Angeles area with tube preamp phrarod Tubes / Valves 4 28th February 2009 04:17 PM
Greetings from Los Angeles dpuopolo Introductions 2 30th July 2007 02:54 PM
Speaker Tech needed in Los Angeles area dmfraser Multi-Way 2 3rd November 2004 11:18 PM
Greetings from Los Angeles Orbit7 Introductions 8 20th November 2003 04:25 AM
Copyright ©1999-2017 diyAudio
