The History of the EL-34 and other Pentodes and Beam Tetrodes.
Old 31st May 2012, 10:10 AM   #21
costis_n is offline costis_n  Greece
Well, If you search for Fantasia Amplifier, you also get the lower 2 racks (the final stage). That's all I know, I just saw it some time ago and thought it was odd to have a Philips tube in there...
Originally Posted by Ronsonic View Post
I need that system.
"I'm changing the climate, ask me how" !!!!
Old 2nd June 2012, 08:53 AM   #22
v4lve lover is offline v4lve lover  Netherlands
The B443 is the first output pentode made by the dutch Philips.
Old 2nd June 2012, 09:33 AM   #23
mvd is offline mvd  Germany
mvd's Avatar
Yes, mentioned first in September 1927
B 443_UX4pin, Tube B443_UX4pin; Röhre B 443_UX4pin ID53758,
B 443_4pin, Tube B443_4pin; Röhre B 443_4pin ID27434, Vacuum
B 443, Tube B443; Röhre B 443 ID1670, Vacuum Pentode
and very rare with three sidecontacts on the socket:
B 443_3SC, Tube B443_3SC; Röhre B 443_3SC ID53582, Vacuum Pe
Text of the Datasheet from Radiomuseum translated to English:
"First output pentode, on market Sept. 1927
Equivalent types: RES174d (Telefunken), L415D (Valvo), PP415 (Tungsram)
Successors: B443S, L416D, RES164
The B443 is the first produced output pentode of the world, introduced by Philips in September 1927. It's amplification and its power output was much higher as with an output triode of equal size. The B443 has established the replacement of output triodes by multiple-grid output tubes. The equivalent Telefunken type RES174d appeared in 1931.
[Jacob Rosch˙, 2003-Jan-14]"
Best regards
Michael
Old 2nd June 2012, 10:51 AM   #24
405man is offline 405man  Scotland
Having read through this posting and some of the links it has reminded me of a question regarding the KT88, The KT88 is often refered to as a beam pentode in the GEC litrature, what is a beam pentode and how does it differ from a beam tetrode
Stuart
Old 2nd June 2012, 02:01 PM   #25
Yvesm is offline Yvesm  France
Yvesm's Avatar
Are you sure of that ?
I always beleived that the "KT" prefix was for "KinkLess Tetrode".
Tetrode stands for four active electrodes, the "Kink" caused by secondary plate emission was suppressd by carrefully aligning G1 and G2 and adding "beam plate" to constrain the electron beam away from their support rods.
This is detailled in the O.Shade paper from RCA.
He clearly explains what is "secondary plate emission".
Some consider this beam plate as an additional electrode and thus count five calling them Beam Power Penthode.
While the name Penthode or Pentode was probably patented by Philips ? ?
Yves.
Old 2nd June 2012, 02:31 PM   #26
barrymagrec is offline barrymagrec
I always understood that the Beam Tetrode was developed to overcome the power Pentode patents held by Plilips / Mullard. When I was about 12 years old (a very long time ago) my dad told me that "a Beam Tetrode is just a Pentode with a funny shaped suppressor grid" Seems to be fair comment.
The History of the EL-34 and other Pentodes and Beam Tetrodes.Hide this!Advertise here!
Output (beam) pentodes / tetrodes suitable for screen grid drive ilimzn Tubes / Valves 19 15th June 2013 06:23 AM
EL-34 to 6P3S-E Laila2 Tubes / Valves 21 1st November 2010 09:13 PM
Beam pentodes and suppressor-grid pentodes of same type jon_010101 Tubes / Valves 3 2nd May 2009 11:18 PM
Single Ended EL-34? jaymanaa Tubes / Valves 11 28th March 2006 10:32 PM
el-34 suggestion mezon Tubes / Valves 7 10th April 2003 09:28 PM
