Old 28th May 2012, 02:50 PM   #1
GentryBa's Avatar
Default Simple DIY Stereo Tube Amp with around 20W
Hello!
I was asking me if there is a very simple (and maybe cheap) tube amp to build somewhere?
From september last year till may this year I built a dual mono F5:
...and equipped it with some µC stuff to check all the values:
rest of the pics:
Pictures of your diy Pass amplifier
it was a very nice project, I learned much about all the stuff...
the next project should be completely analog- and tubes are very fascinating for me, too.
but I don't want to build a tube amp as long as the F5's.
Is there a simple to build tube-amp with a nice sound and cheap cost?
Matthias
Old 28th May 2012, 03:05 PM   #2
Yes! Build an "El Cheapo". It's will yield approx. 6 WPC with triode wired O/P tubes and about 12 WPC with ultralinear mode "finals". A priori, tubed amps cost more per watt than SS. It a matter of magnetics.
Eli D.
Old 28th May 2012, 03:44 PM   #3
yoaudio is offline yoaudio  United States
Or check out Tubelab's Simple P-P tube amp.
$108 for the board and parts to populate the board,
then add your iron and tubes.
This amp produces about 5 watts in triode mode,
or as high as 20 watts in pentode mode.
George is updating his web site, so use the internet
archive-wayback machine to view the assembly manual.
http://web.archive.org/web/201006132...tHere_SPP.html
Old 28th May 2012, 04:11 PM   #4
Default Mullard Amps, start simple!
For people new to Valves (like me) I don't think you can go far wrong with the Mullard designs:-
Articles Contents Page
the 20Watt Amp being here:-
Twenty-Watt Amplifier
I started with the 3-3, here:-
Mullard 3-3. Three Watt Amplifier (see attached Pics) a very simple Amp but taught me a lot. I 'advanced' on to a 3-3 based on the EL33 (see second pic).
Best wishes,
James.
"An AudioPhool and Proud of it!!"
Old 28th May 2012, 06:49 PM   #5
What kind of speakers are you planning to drive with this? Sensitivity?
How big is your listening room and your desired sound level?
What you liked and what you disliked in the F5 ?
These would help people give you more meaningful recommendations.
Old 4th June 2012, 05:20 AM   #6
GentryBa's Avatar
Hello everybody and thank you very much for all the answers!
Speakers I use in the moment:
SB 18 | Lautsprecherbau
They sound soooo nice, and are cheap to build, too...
The F5 sound is very clean and smooth, I love it. You can hear a big difference to all my bought receivers before.
I have heard a tube amp on the bigger brother of the SB18, the SB36:
SB 36 | Lautsprecherbau
This is the tube amp:
EL34 plus MKII
The bass was much deeper, but I think the main reason for this is the bigger loudspeaker?
Its hard to describe my listening, because of my bad english...
The first thing I see is, that a tube amp is not sooo easy to build.
But with your links and tips maybe I can do it!
Thanks again for all the help!
Matthias
Old 4th June 2012, 06:46 PM   #7
If you are building from scratch, I would highly recommend the E-Linear design from Bandersnatch, a/k/a PakProtector a/k/a Douglas. You can find the schematic on this thread in Message #6:
Looking to build a 25-30 WPC Push Pull amp - Need Help
I built a pair of monoblocks using this circuit but on Douglas's recommendation, I used 6AC7 pentodes instead of the 6AU6 shown on his schematic.
Don't be deceived by the circuit's simplicity. Amps using this design are pretty much as good as it gets, in my opinion.
A simple stereo Amp aroud a 2N3773 mjarve Solid State 33 31st March 2013 10:55 PM
DIY Hi-fi Stereo Tube Amplifier el capitan83 Tubes / Valves 19 9th July 2012 04:23 AM
Rowe EC-20W 20 watt vacuum tube amp w/ NOS RCA 6BQ5 tubes installed sid6581 Swap Meet 0 22nd December 2011 01:46 PM
Simple cheap 2A3 stereo amp Gabevee Tubes / Valves 56 10th April 2003 05:25 PM
Copyright ©1999-2013 diyAudio
