B+ delay for DHT amp - diyAudio
Old 27th May 2012, 06:44 PM   #1
Default B+ delay for DHT amp
Hi All
I'm building a DHT amp, I intend to use 5u4-g for B+, but I want to delay B+ 30-40 seconds, what is the best method?
Center tap switch ?
Delay circuit like this RUBLI HTR-214
Or sepperat transformer for heater ?
Best Regards
Fonnesbek
Old 27th May 2012, 07:07 PM   #2
Vinylsavor's Avatar
Hi!
Use an indirectly heated rectifier instead of the 5U4 and you have slow B+ start built in
Thomas
http://vinylsavor.blogspot.com/
Old 27th May 2012, 07:24 PM   #3
yes but indirect heated rectifiers are harder to find and more expensive
Fonnesbek
Old 27th May 2012, 07:59 PM   #4
popilin is offline popilin  Argentina
popilin's Avatar
Try this
My First Power Supply
Old 27th May 2012, 08:25 PM   #5
euro21 is offline euro21  Hungary
Why?
NOS russian rectifiers, for example 5C4S, are cheap and accessible.
5c4s rectifier | eBay
Old 27th May 2012, 08:34 PM   #6
Vinylsavor's Avatar
Hi!
Nothing beats TV damper tubes. Only drawback, you need two of them. Just bought a bunch of 6DQ4s for 35 cents each.
Thomas
Old 27th May 2012, 09:31 PM   #7
To have a perfect onset of B+ exactly 40s after startup you need a separate timer board. You can build it or you can buy it.
eBay Italia - Aste online e shopping a prezzo fisso
I use this in my project. It works very well and the delay is selectable via a pot. also you can switch between seconds and minutes (by setting a jumper).
Old 28th May 2012, 05:58 AM   #8
Originally Posted by popilin View Post
Nice. Thanks!
Old 28th May 2012, 09:02 PM   #9
djn is offline djn  United States
djn's Avatar
A pair of 6D22S half wave diode tubes work great as they take 36 seconds to warm up. Cheap as well.
Old 28th May 2012, 11:53 PM   #10
FullRangeMan's Avatar
Hi All
Center tap switch ?
Best Regards
Fonnesbek
I like a 30 seconds delay for the ''power on'' in rush. The 6C33 warm-up time is 600 seconds, after it the tube is OK to receive the HV B+, 600 seconds is a bit longer to a delay circuit or clock.
Iam negatively surprised with all commercial tube amps builders, nobody use two power switches, only Atma-Sphere use it.
A power on switch cost around 0.25 dollar in China, an delay circuit is much more expensive and need more hand work.
I like plain simple solutions, they are hard to fail.
There is any reason why all these brands do not use two power on switches Iam unaware?? in favor of more complicated delay circuits.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
HQ-DHT (All tube DHT amli) 26-45-2A3 quanghao Tubes / Valves 44 20th January 2013 10:58 AM
one stage DHT amp Jaime Tubes / Valves 2 18th October 2010 01:31 PM
F* amp VS Single Ended DHT tube amp xecluded Pass Labs 15 11th August 2009 08:59 PM
An all DHT push pull amp. Eusebius Tubes / Valves 3 28th October 2006 01:37 PM
DHT Triode Amp Project gilid Tubes / Valves 17 4th February 2003 12:26 AM
Copyright 1999-2017 diyAudio
