Old 27th May 2012, 10:23 AM   #11
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Originally Posted by pergo View Post
In my amps there are always 3 DC-DC converter (12-->+-40V, +40V --> 300V, +40V ---> 6.3V)
On Ebay you find the Nixie power supply, large as a dollar-coin, from 12V up to 450V@10mA or 225V@20mA.
I mean no disrespect to anyone here, but both of these scenarios are a long way from the power supply that the OP was asking about. The fact that the OP was asking the questions that they were suggests that they might not have a full understanding of the implications. The types of DC-DC converter that you are describing are a world apart from those found in the power supply under consideration.
Old 27th May 2012, 10:52 AM   #12
Yes, it's the rectified supply rail after an active PFC - thus not isolated from the mains! In an active PFC the rectified DC voltage has to be higher than the peak AC input voltage (AC voltage times square root 2), otherwise the PFC regulation wouldn't work.
Best regards!
Old 27th May 2012, 10:58 AM   #13
Rewind the transformers in the smps or use voltage doubling.
After that you still have noise issues to deal with.
Tried a few mods of computer PSU´s but still like the linear approach.
Old 27th May 2012, 12:08 PM   #14
srinath is offline srinath  United States
I will check for continuity but I should tell you there is a transformer and maybe 6 or 8 transistors in that 1/2 of the psu before the 420v output. From here on to the output there is 2 more transformers and 10-12 transistors. I will check for continuity though.
I should put a few pics up too I guess.
Cool.
Srinath.
Old 27th May 2012, 11:50 PM   #15
Its got continuity, somewhere around 1,800,000 ohms. Oddly that is the resistance from either of the 2 outputs to the 2 + and - input prongs. So lets call it prong 1, 1 to + ac input = 1.8m ohm, prong 1 to - ac input = 1.8m and prong 2 to + ac is 1.8m, as is prong 2 to -.
So what does it mean.
I will post a pic in a bit.
Cool.
Srinath.
Old 28th May 2012, 02:11 PM   #16
Default Power supply pics
The power supply pics are attached.
420vdc across that white 2 pin plug. 42vdc out from the plug in the back - and there is about 1.8m ohm from there to the 2 pin plug as well. I cant measure anything over 2m ohm and I read over that or open from the full on output pin to the ac input -
Cool.
Srinath.
Old 28th May 2012, 03:49 PM   #17
astouffer's Avatar
Doesn't look isolated.
Old 28th May 2012, 08:49 PM   #18
I measure continuity between the B+ and B- prongs on other amps too, my onkyo tx-ds-555 and a few others read less than 1.8 m.
Cool.
Srinath.
Old 28th May 2012, 08:58 PM   #19
astouffer's Avatar
You'll read that through a bridge rectifier. Its still NOT isolated. Hook it up to something with an earth ground and you have a 50/50 shot of seeing fireworks.
Old 28th May 2012, 09:05 PM   #20
I dont quite understand - this SMPS also has a rect. bridge etc etc ...
Cool.
Srinath.
Modify Power supply for Tube Amp gnometto Tubes / Valves 5 7th February 2012 10:35 AM
Small Tube Pre Amp - Power Supply Cable ervinl Tubes / Valves 1 7th July 2010 10:02 AM
DIY tube amp power supply frenchie29 Tubes / Valves 13 12th January 2010 11:07 AM
Power Supply Module for Tube Amp gijoe_22 Vendor's Bazaar 8 16th December 2009 02:25 PM
Question about tube amp power supply caps gjo Tubes / Valves 12 26th March 2006 11:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
