PSE 2a3 operating points? - diyAudio
Old 26th May 2012, 09:12 AM   #1
Default PSE 2a3 operating points?
I have a pair of Audio Note TRANS-152 OPTs which are gapped for 90mA and 2.5K into 8 ohms. I was thinking of 300b but revised this idea to PSE 2a3s. I intend to use the biplate versions, or the biplate Russian 6C4C, which is a 6B4G.
The 6B4G data sheet states 250v and 60mA in SE, class A
http://www.mif.pg.gda.pl/homepages/f...127/6/6B4G.pdf
It also states 325v and 40mA in PP, class AB1
I'd like to get somewhere around 45mA each tube, but with these biplates how high could I take the Anode-Cathode voltage? Any suggested operating points? Anybody tried out 2a3 in PSE?
Andy
Old 26th May 2012, 10:39 AM   #2
Vinylsavor's Avatar
Hi Andy,
For PSE I would stick with the max plate voltage of 250V. Since your OPT is gapped for 90mA I would run the tubes at 45mA each.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 26th May 2012, 10:55 AM   #3
250v and 2 x 45mA gives 22.5w anode dissipation so just possible. I'd like a bit more. I have Mark Audio Alpair 10 fullrange speakers. 2a3 PP drives them beautifully! They're about 290v A-K and 45mA
andy
Old 26th May 2012, 02:51 PM   #4
Vinylsavor's Avatar
Hi Andy,
if PP drives them nicely why not stick to PP then?
Thomas
Old 26th May 2012, 03:27 PM   #5
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by andyjevans View Post
I intend to use the [...] Russian 6C4C
[...]with these biplates how high could I take the Anode-Cathode voltage?
I have some of these Russian tubes. The data sheet says the max is 360V (attached).
I put all 10 of mine, in turn, into a mono-block running at less than this and a couple of them had some initial 'pops' until they settled down. Maybe you want to burn-them in gently before exposing them to full B+ if you are planning to use a high voltage.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
6sn7 operating points AudioGeek Tubes / Valves 24 2nd February 2017 09:44 PM
6LW6 operating points AmpKiller66 Tubes / Valves 10 9th December 2014 11:46 AM
Operating points theory... lt cdr data Tubes / Valves 3 29th June 2011 10:34 AM
PX25 operating points bcherry Tubes / Valves 12 27th June 2003 11:24 PM
Copyright 1999-2017 diyAudio
