I have just made a class ab gtr amp.
my measurements came out a little off on the chassis for tube location. a JJ6L6GC is too tall.. and tends to hit the spkr. magnet. turns out with a minor tweak.. the 6p3s would be just right and give me the tone I want. I have an old.. can't read the label 6L6gc that fits. JJs too tall. I can't find the dang dimensions anywhere.. save one place that show them so small I can't read it and wont enlarge.. probably my fault there. anyone know how tall they are compared to a JJ? I'd never have thought I'd spend half an hour looking.. sheesh. |
#2 |
#3 |
115mm = 4.5inches..
I'm assuming.... the 6L6GC GE at 3.5" is the same as the 6p3s. that seems to be the size of the old 6L6GC I have.. no dang label. |
#4 |
![]() you can see the jj el34 and jj6L6GC are too tall. the broken one is like the one I have in now..it fits. the JJ 6L6 just ticks the magnet.. damn my old eyes for measuring that.. the JJ6V6 is just a tick shorter than I'd need. I found some Russki 6P3S-E and I think they will do the job for fit in size and circuit. man I nearly blew this build.. but in the end it really rocks.
#5 | |
Can we see your build? jeff |
#6 |
Thanks!
I didn't know they were called coin based. Makes sense. Here's some pics cosmetically it's not finished.. lotta holes from the amp that was in there.. it'll be white pearl panel on front.. haven't decided on the rear panel yet. and the combo cab will get some work, too. the last test on the bench.. and hey. a clean bench is a sign of a warped mind! an old time radio guy told me that, and I'm sticking to it. ![]() this shot is pre finish on the mess .. needs a couple parts glued down.. and a couple need to be radial caps instead of axial.. all I had on hand was axial. ![]() the top shot for some reason my camera didn't take the front shot. got it in the cab now.. I'll put in a 'finished' pic later. ![]() it is in this cabinet
#7 |
That's a nice looking cab.
jeff |
#8 |
Thanks.
Raven RG60 solid state. still got the guts laying in the shop. Will put them in something. If you look around you can find the RG20 1X12 combos for 50.00 or so. Way cheaper than buying a new cabinet.. chassis are steel, too. You just have to be careful the tubes clear the speaker magnet before you start. I will retolex the amp above.. when I get time. I ran into a big chunk of what simulates nearly .. cowhide. the brown black white kinda look.. like I shot a dairy cow. *G* Here's the RG20 converted to a Tweed Deluxe 1X12 combo ![]() Here's my RG60 converted to Marshall clone 1X12 combo ![]() now I spose the dang prices will go up. *L* note: the new 'acoustic' amps at GC are in fact Ravens.. GC bought the name. They are different mostly cosmetically.. with some features improved a bit. So keep an eye out for those showing up. Any old solid state will have a good box.. and even a decent chassis.. Great for rebuilding if there is tube clearance.. not typical on smaller models which have 10" or smaller speakers though. use good stuff to build it, and it will rock!
#9 |
#10 |
I'm quite a fan of the old 6P3S-e. Cheap, built like tanks and they actually sound great. One of the Sovtek 6L6's (can't remember the exact code off the top pf my uead) are actually just rebranded 6P3S-e tubes. IIRC those Sovtek's come stock in Marshall and Soldano amps these days, but don't quote me on it.
The only 6L6 variant I've heard that sounds smoother are the current production TungSol's. Which, by the by, are actually 5mm to 10mm shorter than the 6P3S-e (the latter having a resonably large height variance between tubes, I've seen up to 5mm or so difference)
I Reject Your Reality And Substitute My Own - Adam Savage, Mythbuster |
| Datasheet for Russian 6p3s-e | Ty_Bower | Tubes / Valves | 30 | 19th August 2012 06:54 AM |
| 6P3S-E Cathode Resistors | Saracenblue | Tubelab | 7 | 7th June 2012 11:01 AM |
| 6P3S-E in place of 6V6 | MellowTone | Tubes / Valves | 9 | 12th July 2009 08:57 PM |
| 6p3s vs kt 88 | hbi | Swap Meet | 6 | 28th November 2007 05:25 AM |
