Want help - RCA Tube Manual RIAA Phono Stage - Page 3 - diyAudio
Old 12th June 2012, 01:24 AM   #21
Both boards have been stuffed, and tested. They work to my satisfaction.
I have learned from this effort. I replaced some caps as was suggested.
Next project is to build a stereo version of the RH-84 power amp to run
the pre-amp into. I have a PC board for that project also.
Thanks to all who helped.
Old 15th June 2012, 08:47 PM   #22
A photo of the finished amp.
Old 16th June 2012, 12:55 AM   #23
kevinkr's Avatar
Very Cool.. At some point in the future have a look at replacing those ceramic caps with polystyrenes - they should be significantly less microphonic as well as generating less distortion.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th June 2012, 09:04 PM   #24
soulmerchant's Avatar
Excellent work Bruce. If you have a residual hum at loud volumes you can shield it with a metal box. Poly caps in the RIAA will make it sound really great too of course.
Old 22nd June 2012, 04:53 PM   #25
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
E.T. , when you quote, please do not edit in any other way than making it shorter
please do not change any words etc
moderation
your post have been removed
Old 24th June 2012, 02:14 AM   #26
Triodethom's Avatar
look good. Some grommets where the wires pass in to the chassis will protect them . This is great for a first try at a phono section . Regards
Old 28th June 2012, 11:55 AM   #27
Question tweaked RCA setup
Originally Posted by Eli Duttman View Post
Look at the tweaked RCA setup, with its source follower buffer that can drive a load.
Hi, Eli
Thanks for sharing!
Here are 3 ground symbols drawn, I hope only one is chassis connected?
What reason is to increase caps values (from 20uF to 30uF)?
+ And why at output two capacitors (0.47 + 5uF) are used? One is ever better (for sound) as two in parallel...
www.Levelfive-Audio.com
Old 28th June 2012, 04:19 PM   #28
And another little question.
Are 39K and 15K for both channels or only for one?
(the same question about 30uF caps)
Old 21st October 2012, 10:51 PM   #29
Bigun is offline Bigun  Canada
Bigun's Avatar
Nicely done ! (if it's not too late to say so).
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th January 2013, 11:38 PM   #30
I am seriously thinking of making one, I have the original manual RCA and all contributions are most useful
My congratulations also never too late!
Recommendations for Phono Stage (RIAA?) LucasAdamson Analogue Source 18 10th November 2009 08:16 AM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 04:00 AM
My RIAA Phono Stage Project sorenj07 Tubes / Valves 16 10th September 2006 09:18 PM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 01:05 PM
Tubed RIAA phono stage shif Analogue Source 7 30th June 2004 06:22 PM
Copyright 1999-2017 diyAudio
