Want help - RCA Tube Manual RIAA Phono Stage - Page 2 - diyAudio
Old 30th May 2012, 05:21 PM   #11
kevinkr's Avatar
I took the liberty of editing the thread name so that its subject is a little clearer.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 30th May 2012, 05:28 PM   #12
Kevin
Thanks for your input. After I get the pre-amp powered up and hear what
it can do I may make the changes you suggest. I have been told that this
pre-amp sucks to the max so I dont want to spend anymore money than I
have to for now.
thanks
Old 30th May 2012, 05:31 PM   #13
rongon is offline rongon  United States
rongon's Avatar
About 15 years ago, there was a commercially available circuit board for the RCA RIAA preamp (from Handmade Electronics, I believe). I stuffed one of those, put it in a nice chassis with power supply, and added another tube socket for a 12AT7 cathode follower, to help with the output impedance problem. The result sounded quite pleasant.
Old 30th May 2012, 05:38 PM   #14
smbrown is offline smbrown  United States
smbrown's Avatar
Bruce, I'm not sure I'd say it "sucks to the max" I personally really enjoy this stage and have built a number of them over the years. My favorite uses 6SL7s (or 12SL7s) instead of the 12AX7, but this would not work on your board since the SL7 is an octal tube. At any rate, if you use it within the limits give (like next stage needs 250K or greater input impedance) you may be surprised just how much it doesn't suck.
Old 31st May 2012, 12:04 AM   #15
I also built the Handmade kit. Designed by Gordon Rankin, it was a nice implementation. Mine is on the sideline right now while I come up with a new power supply for it.
Old 31st May 2012, 12:49 AM   #16
Ivey is offline Ivey  United States
Ivey's Avatar
Default TUBECAD PHONO AMP, MOD RCA PRE-AMP
Bruce:
Here the layout of a modded RCA clone. My great grandfather copied it from Tubecad. I listen to it for years now. It sounds outstanding.
I include the article and the pcb layout.
I hope this will help. I ask you great grandfather and he stated that good metal poly caps can be used for the RIAA.
Joe
"Have anyone seen my Smart Phone"?
Old 31st May 2012, 12:58 AM   #17
Ivey's Avatar
Here is a copy of the article and schematic.
Joe
Old 1st June 2012, 03:16 AM   #18
cerrem is offline cerrem  United States
cerrem's Avatar
Without getting to in depth.... Here are a few basic to strive for to make this simple RIAA stage pleasurable to listen to...
1. RIAA ACCURACY....this is pretty much trivial transfer function...just basic math to figure the proper values for POLES and ZEROES.... The bigger question is if you even care...since a sloppy RIAA curve will make some audiophiles go balastic while other listeners can be very happy and don't mind.... Keep in mind that MANY pressing were cut with sloppy RIAA curves to begin with....
2. HEADROOM.... are the tubes biased nicely??? Will a loud passages cause clipping and go to the rail??? The worst part of clipping is that the RIAA caps will get charged up to the rail, then they need "time" to recover...not good...
In the old days they used "1812 Overture" as the transient overload test record... then you ask yourself...is it my pre-amp??...or is it the cartridge not aligned properly?? Oh maybe the recording was distorted??? Or maybe all the above??
3. NOISE FLOOR......What you can do to minimize noise.....carbon comps for the added warmth...or metal films for the cold and sterile truth.....
4. VOLTAGE REGULATION.... I prefer good voltage regulation for linearity....but with that comes NOISE from the regulator/ reference.... A reg with a low noise floor is key to a good RIAA stage and this RCA phone stage is no exception...it will make it come alive...
Have fun with this phono stage....It may not be the best design...but having good supporting circuitry can make all the difference....
Chris
Old 2nd June 2012, 01:59 AM   #19
To all who got involved, Thanks for your input.
The last of the missing components showed up in todays mail.
I finished stuffing the board, constructed a crude voltage doubler power supply and fired up the pre-amp. It worked without a single problem, and sounded much better than I expected. It is very quiet considering the power supply I used for testing. Now I will build anothr board, get a chassis and
construct a real power supply to make a stereo unit.
Just for fun, I tried several tubes to hear how it would sound.
First was a 12AU7, (not very loud but worked). Next was a 12AT7, (sounded better and just a little more volumn), then a 12AX7 (loudest and best sound).
I also put the Russia 6n6P It worked pretty nicely also. I'm staying with the
12AX7. If anyone would like to built a pre-amp, you can use my PC board layout, it works well.
Old 2nd June 2012, 12:29 PM   #20
rongon's Avatar
Yes, definitely stay with 12AX7!
An RIAA preamp is no place for "tube rolling." The 12AU7 and 6N6P are radically different from 12AX7. Nowhere near the same amplification factor, plate resistance or transconductance. The frequency response of the preamp will be greatly altered by putting in such different tubes. It would deviate widely from "flat" response (adherence to the RIAA characteristic). It's no surprise that you wound up preferring the 12AX7 in this preamp. That's what it's designed for, so of course that is what will work best in that circuit.
Recommendations for Phono Stage (RIAA?) LucasAdamson Analogue Source 18 10th November 2009 08:16 AM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 04:00 AM
My RIAA Phono Stage Project sorenj07 Tubes / Valves 16 10th September 2006 09:18 PM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 01:05 PM
Tubed RIAA phono stage shif Analogue Source 7 30th June 2004 06:22 PM
Copyright 1999-2017 diyAudio
