Thorens TEM 3200 clone - Page 5 - diyAudio
Old 28th June 2012, 09:21 PM   #41
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
Opened a webpage about this project.
DC coupled Hi-end Hybrid Amplifier
In the listening test with some my friends were overcome a lot of the performance of my previous End Amplifier
Amplifier End by Andrea Ciuffoli
Old 29th June 2012, 05:43 AM   #42
Banned
No ideas has been received about the original clone so this thread can be closed.
The developments on my new Circlotron project will be described in the relative web page on my web site.
Old 22nd December 2012, 08:12 PM   #43
Klick is offline Klick  Germany
I have a quick and dirty concept how the tube-part perhaps can be built
after tube2 is a Resistor as Levelshifter.
Old 30th November 2013, 12:32 AM   #44
tiefbassuebertr's Avatar
Default TEM 3200 in used condition anywhere available ?
I am looking for an used TEM 3200 in perfect or faulty condition.
Who know, who may offer such a device?
Thank you for advices.
And a second question:
Who can upload a schematic diagram from this model ?
Old 2nd December 2013, 03:23 AM   #45
ilimzn is offline ilimzn  Croatia
Trivial problem, feedback has to go from the other side of the circlotron. However, the phase then relies on the input transformer to do correct phase splitting. Otherwise, your input stage (1st) must be set up as a differential amplifier so it does the phase splitting itself. Feedback can still be connected to the 1st stage cathodes, but I'll leave it to you to figure it out, it's not too difficult
Old 2nd September 2015, 02:49 PM   #46
HI
A full solid state version is possible ?
Old 2nd September 2015, 04:49 PM   #47
smoking-amp's Avatar
Looks like all the circuit ramblings have missed the obvious TEM3200 front end design.
The EC86 and CV6189 are both hi gm tubes. So use them together as an asymmetric differential pair (a separate pair on each phase side). Input goes to the EC86 grid, and N Fdbk goes to the CV6189 grid. CCS tails for each side (notice -Ub for each side). Plate of the CV6189 drives the 6S3P cathode follower grid.
Edit:
Looks like the 6S3P is the input, and the CV6189 is the 2nd half of the diffl pair, with the EC86 as the follower here: http://www.6moons.com/audioreviews/thorens/thorens.html
Essentially a tube Op-Amp version of the SUMO9+
"I don't need facts, I'm smarter than you." - Maximum Emperor for life: Mor_hon_Bunkum_Un (Hanged 6 months later after announcing his new health care plan would only cover burial expenses, or a round of golf at any of his posh resorts.)
Old 7th September 2015, 11:57 AM   #48
Hello, I simulated the patent with OPAMP :
0.001% 10khz 1W 8ohm (4V)
0.02% 10khz 120W 4ohm (31V)
https://sites.google.com/site/solidc.../OPAtriple.asc
I tried with a follower but it does not work
https://sites.google.com/site/solidc...oOpaBuffer.asc
Old 7th September 2015, 02:59 PM   #49
What is the problem with the buffered version? Oscillating? Maybe need fast Fet buffers.
On the tube version:
"Uniquely, the Thorens then adds a 6-tube input/driver stage with complete DC coupling from input to output to avoid any and all coupling caps."
"Just as Bongiorno's patent concerned itself with how to bias the floating counter phase circuits, so the secret of the Thorens lies in its three potted modules. They perform the precision servo biasing so critical to a high-power output stage that's not referenced to ground."
The 6S3P input gets cathode coupled to the CV6189 with a CCS tail.
Then probably has Gyrator loads on the CV6189/6688/E180F pentodes to control DC levels to the EC86 followers, and to provide high AC gain from the CV6189 pentode plate, to resemble an Op Amp. Then probably a bias servo on the final CCS tail for the EC86 buffers to control Mosfet bias. (making for three potted modules) (an additional resistor between the EC86 cathode and the Mosfet gate feed, so the controlled CCS can vary bias) The 300 Amp output module Mosfets are trivially loaded by a speaker load, so have virtually no distortion to begin with for the Op Amps to fix. Hence the super low distortion figures.
This should really be a simple design to make DIY. I would suggest just using $1 6JC6 frame grid tubes for all the tubes (possibly use 12GN7 or 12HL7 tubes for the followers). A $200 Amp to build from parts (mainly power supply, input xfmr, and Mosfets).
Old 7th September 2015, 03:51 PM   #50
late edit:
Mosfet modules with a built in thermal monitoring diode or thermistor would be preferred, for fast control of the variable bias CCS.
The low distortion figures do mean that this doesn't sound like a tube amp, by the way.
Krohn-Hite 3202(R) and 3200(R) Filter jackinnj Equipment & Tools 6 4th November 2016 04:41 PM
Cloning a $3200 Speaker for $400 Patrick Bateman Multi-Way 95 6th February 2016 07:38 PM
Problem With Denon Avr 3200 ostie01 Solid State 4 21st July 2005 08:38 PM
Copyright 1999-2017 diyAudio
