Thorens TEM 3200 clone - Page 3 - diyAudio
Old 4th June 2012, 11:15 AM   #21
tiefbassuebertr's Avatar
Originally Posted by audiodesign View Post
I don't like the cross feedback
What is from your view the main disadvantage by circuit from post #18 in opposite to that one from post #17 ?
The input cascode (at first look a differential amp) from post #17 provides rather an advantage compare with a normal one-stage input section from post #18.
OTOH - crucial should be the audible differences between both solutions.
Old 9th June 2012, 08:33 AM   #22
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
I have got a copy of Linear Audio magazine - volume 0 (Linear Audio | your tech audio resource) to read the article of Frank Blöhbaum about New Low-Noise Circuit Approach for Pentodes.
I am selling this book
LInear Audio book volume 0 | eBay
In the Frank Blöhbaum article it described only a useless configuration called "best pentode"
Old 9th June 2012, 08:42 AM   #23
Banned
tiefbassuebertr,
yes the differential is not a bad solution about feedback
Actually I am working to a servo loop to have no dc offset because after some test with the hybrid configuration with mje15032 I have seen a very low stability using only a trimmer.
Old 15th June 2012, 07:13 AM   #24
Banned
new version in testing phase
Old 18th June 2012, 07:23 AM   #25
Banned
new version schematic to test and previous version driver stage measurements
Old 18th June 2012, 10:43 AM   #26
Banned
Some photos
Old 19th June 2012, 08:16 AM   #27
Banned
last version with driver meaurements
Old 19th June 2012, 10:53 PM   #28
Banned
Nice project!
Any plans to try the Semisouth JFETs in the output?
Old 20th June 2012, 09:12 PM   #29
Originally Posted by Nelson Bass View Post
Nice project!
Here two other circlotron topologies:
My JFET project
The Amazing Fet Circlotron by Mike Rothacher
I would try to replace the tube with a VAS stage like this (introduced magic resistor and cascoded cascode):
http://peufeu.free.fr/audio/memory/memory-5-vas.html
This topology must actually clearly beat all exist small signal tubes in all respects, as long as high supply voltage is still present.
Old 21st June 2012, 08:11 AM   #30
Why is it useless in your opinion?
Krohn-Hite 3202(R) and 3200(R) Filter jackinnj Equipment & Tools 6 4th November 2016 05:41 PM
Cloning a $3200 Speaker for $400 Patrick Bateman Multi-Way 95 6th February 2016 08:38 PM
Problem With Denon Avr 3200 ostie01 Solid State 4 21st July 2005 09:38 PM
Copyright ©1999-2017 diyAudio
