Old 24th May 2012, 09:36 AM   #11
tiefbassuebertr's Avatar
Originally Posted by audiodesign View Post
I cannot apply the negative feedback because the second stage does not invert the phase.
The second stage is a potential shifters created with a screen driven pentode.
So probably Thorens use another configuration for this stage.
For a clone you will need at first the detailled (or st at least the simplified) schematic diagram of this Thorens power amp.
The serial NFB network from the circuit attached by post #6 consists of R14/6 for the left half and R15/7 for the right half
Voltage gain factor is additional dependend from R17/4/5 resp. R16/10/11.
If only the first stage does invert the phase, only a parallel global NFB or a local serial feedback by the first stage is possible (by the use of one voltage gain input stage and two follower/unity gain stages resp voltage shift stages).
If I had the simplified schematic from the TEM3200 I could say more details.
For your clone also ths thread could be of interest:
Biasing schemes for bipolar transistor circlotrons
P.S. Causing the wrong filing you don't get the right amount of replies. The right file for this thread is "Solid State" because only the front-end uses tubes.
Old 24th May 2012, 07:20 PM   #12
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
I will test soon one channel of this amplifier.
This is the result of many simulations so I am interested to ear the sound.
The design allow:
1) extreme high slew-rate
2) low distortion with low feedback
3) high frequency range 0Hz to 1MHz at 0dB
4) no switching output stage like a pure class A
5) 4 trimmer to set zero offset and individual mosfet bias
6) all driver are single ended
7) the global feedback is managed by a tube
8) low voltage power supply are necessary +150, +150 and 6.3 for the filaments
9) open loop feedback easy to modify
10) no high power resistors
It is necessary a balanced input but this is not a problem because my new USB DAC 3 will have this type of output and all current production DAC chips are balanced.
Old 24th May 2012, 07:22 PM   #13
I am still waiting an help for second stage of the TEM 3200 "clone".
Old 24th May 2012, 07:30 PM   #14
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
in schematic in post #12 you have one redundant stage in each half
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 25th May 2012, 08:16 AM   #15
What you mean ?
R5 and R10 set the dc offset for each output
R4 and R25 set the mosfet bias
Old 26th May 2012, 08:24 AM   #16
I have got a copy of Linear Audio magazine - volume 0 (Linear Audio | your tech audio resource) to read the article of Frank Blöhbaum about New Low-Noise Circuit Approach for Pentodes.
Old 28th May 2012, 07:16 AM   #17
This new schematic resolv the problem of feedback phase but using a differential stage the voltage gain is lower.
Open loop:
30Vpp with 2 x 2Vpp
10.6Vrms with 2 x 0.7Vrms
Old 28th May 2012, 10:37 AM   #18
Another solution is cross the feedback
102Vpp with 2 x 2Vpp
36Vrms with 2 x 0.7Vrms
Old 28th May 2012, 11:57 AM   #19
I don't like the cross feedback
Old 4th June 2012, 08:27 AM   #20
taniknight's Avatar
Hi Andrea,
I am following along and looking forward to reading about your findings. Thanks for posting.
Tani.
Cloning a $3200 Speaker for $400 Patrick Bateman Multi-Way 40 14th July 2012 03:48 PM
Krohn-Hite 3202(R) and 3200(R) Filter jackinnj Equipment & Tools 5 23rd June 2010 11:18 AM
Problem With Denon Avr 3200 ostie01 Solid State 4 21st July 2005 08:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
