James PP Audio Transformers, any good? - diyAudio
Old 21st May 2012, 01:53 AM   #1
mbeards is offline mbeards  United States
Default James PP Audio Transformers, any good?
I am wondering what luck people have had with the James audio transformers?
....particularly their push pull product line. I have seen people comment on the single ended stuff but I am wondering how their push pull outputs sound.
I am thinking about getting a pair for a Acrosound ultralinear 6550 project that specifies 3.3K primary. This sounds about right for a 450V supply that will sag under full power, but I am having difficulty finding some higher end transformers than the Edcor's with a 3.3K primary.
James has a 3.4K so I sent them an email requesting a price.
Just wondering what successes people have had with their high power PP OT.
Any other transformer suggestions would be great.
-Matt
Old 21st May 2012, 03:06 AM   #2
rmyauck is offline rmyauck  Canada
Unless you are looking for every last bit of power from what I've read studying the subject, you might be better off with 5K for less distortion. Back in the day they they were after max power and also ran the tubes to the max. You will loose a slight bit of power. This will also allow you to roll some lower power tubes too if you adjust the bias. 6K would work fine too.
Your right you don't see any builds with the James for PP. Maybe similar style Hashimoto if you can afford them or Lundahls (make sure to get UL version) for less. Both are C cores (HW versions of Hashimoto PP not HWC) Dave Slagle of Intact Audio may be the only NA maker of C core transformers which would also be great if in your budget.
Hope that helps!
Randy
Old 21st May 2012, 03:14 AM   #3
dsavitsk's Avatar
James seem to be very good for the price. The only issue is that there are no US dealers who carry the push-pull type, and shipping from the manufacturer can be quite high. If you need 12, it is less of an issue. But, for the price of 1 pair + shipping, you can pick up something locally made -- Electra-Print, Magnequest, Onetics, etc.
Old 21st May 2012, 03:27 AM   #4
Good thought on increasing the primary impedance! I think increasing 3.3K is the way to go.
Hashimoto's are out of my price range. Lundahls seem more reasonable.
Old 21st May 2012, 03:30 AM   #5
Just stumbled across these as well:
Push-Pull Transformers - Transcendar Audio Transformers
SE and PP James and Silk Transformers for Sale ppereira Swap Meet 3 29th November 2011 08:33 PM
A New Source for James Transformers dsavitsk Tubes / Valves 2 6th April 2009 09:16 PM
James Transformers Andersen Tubes / Valves 2 21st October 2007 12:22 PM
calling Moray James, and others ..wav8 or 6BM8 schemtics--PP. Nanook Tubes / Valves 15 2nd July 2007 08:12 PM
james transformers billr Tubes / Valves 6 10th May 2005 12:17 PM
Copyright 1999-2017 diyAudio
