6e5p WCF headphone amp with no cap! - Page 6 - diyAudio
Old 1st June 2012, 11:10 AM   #51
This topology should do it with only one the lovely 6E5Ps at 100V/60mA. No caps and a low Zout with the help of a "garypimmish" battery-biased CCS(cascode is no problem). Will keep THD well below 0,1% too.
Old 1st June 2012, 11:15 AM   #52
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Interesting Lars. Can you please explain the topology, is it an anti-triode configuration?
thanks
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 1st June 2012, 11:27 AM   #53
Havenīt cared to name or define it. But anything with "mu" will do.
With P-channel depletion MOSFETs on the market it would have been even easier to accomplish.
Old 1st June 2012, 11:30 AM   #54
mogliaa's Avatar
Well, it looks to me like a gyrator with a mu or anti-triode output (I think Michael Koster named it or referenced it as such), correct?
Old 1st June 2012, 11:38 AM   #55
Same function. Gyrator this time?
Old 1st June 2012, 11:48 AM   #56
mogliaa's Avatar
Indeed, but I thought that when the output was taken from a midpoint of the source resistor, that would provide the lowest Zout (Zout/2) compared to the gyrator equivalent?
Wouldn't that be the case when taking the output from the pot?
Old 1st June 2012, 11:59 AM   #57
NO, no gyrator at all this time this time. Look at the battery as a signal short. If you take the output from the midpoint, Zout gets higher, not lower. When taken directly from the source Zout will be just a few ohms. When taken from the midpoint you will get a useless ballpark Zout of 30-40ohm. So Antitriode is no option here.
Old 1st June 2012, 12:14 PM   #58
mogliaa's Avatar
Ops, my fault. I didn't look at the circuit properly. So it's just a gyrator...
Will simulate this one then to study it a bit more, thanks!
Old 1st June 2012, 12:24 PM   #59
Noooo, the second one is NO gyrator, the cap can be omitted.
Question is wether the the battery would harm fidelity? No current through it so one could try Lithium cells. Thorsten L. used them in series with signal when adding grid bias. Think he bypassed with a small cap and a large resistor though.
Looking forward to your findings. Have never used and will never use headphones but I still find this subject amusing.
Old 1st June 2012, 02:05 PM   #60
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Headphones make my hearing aids whistle.
Interesting design.
Low power JFET WCF Osvaldo de Banfield Solid State 2 20th April 2012 12:10 PM
What would be the correct output cap for this OTL Headphone Amp? pingfloid Tubes / Valves 26 2nd January 2012 03:51 PM
6E5P Jaime Tubes / Valves 6 10th March 2011 07:17 PM
Humming from WCF but not SRPP Brit01 Tubes / Valves 5 22nd August 2010 08:37 PM
6e5p Vladi59 Swap Meet 0 18th March 2009 07:26 PM
Copyright Đ1999-2017 diyAudio
