Old 26th May 2012, 08:57 AM   #41
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
I wish I had an AVO!. After so much work managed to get my curve tracer working well. It's a challenge though to trace high gm valves, as the bias point tend to drift a bit so need to readjust just before taking the picture with the camera.
Will do some tests with the 6e5p when I get the time
thanks for the help
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 26th May 2012, 09:01 AM   #42
The risk of getting gridcurrent in a CF is extremely small wrt to the present signalvoltages.
About high Gm tubes you have to let them stabilize for at least 0,5-1 hour. I have an old AVOIII, it works great even with hi-Gm tubes like 6C45 etc.
Old 27th May 2012, 08:39 AM   #43
mogliaa's Avatar
Hi Lars,
Indeed, the valve stabilised after 20-30min. I managed to get a model very close to Dmitry's.
http://www.bartola.co.uk/valves/wp-c...iode-model.png
I may have recorded incorrectly the tracer settings as it seems like the grid start voltage was -2V and not 0V....
Here is the model
http://www.bartola.co.uk/valves/wp-c...pice-model.txt
Ale
Old 27th May 2012, 08:51 AM   #44
I was looking at the datasheet of that valve and the lifetime is stated 500 hours ?!?!?!
In that case, maybe the Pa (max) is optimistic. Just a thought.
Old 27th May 2012, 09:38 AM   #45
mogliaa's Avatar
Indeed. However can't comment on that as haven't used it yet.
Interesting to see that there is a close brother of this valve, the 6e6pe. Longer life one with similar characteristics. It's a bit price though, but may be worth looking at this one as well....
Old 29th May 2012, 10:53 AM   #46
Go for 2*E182CC(4*triodes) instead!
Old 29th May 2012, 04:04 PM   #47
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Another thing to remember is that if you are using cathode bias, grid current does not start when the input signal peak is equal to the bias voltage in magnitude.
This is because of the feedback from the cathode resistor. In simple terms, when the input voltage is 1.3V peak and the bias is 1.3V, you induce an additional voltage drop in the cathode resistor of (24mA/V*1.3V)*32) = 0.998V !
Of course this becomes a cat-chasing-its-tail situation since the increased voltage drop reduces the differential due to the input voltage.
Old 29th May 2012, 05:18 PM   #48
DF96 is offline DF96  England
The arithmetic in your second sentence is wrong, but your third sentence suggests that you know this.
Old 29th May 2012, 05:40 PM   #49
hoktuna is offline hoktuna  Sweden
I have a stash(20) of 6E5P and i also got Lars old AVO
I guess it it is a good tube,they are all pretty cloes match.
Iwe got at least three quarters of 25 pice.
Old 29th May 2012, 06:43 PM   #50
mogliaa's Avatar
I have 6N6P which are close equivalent to the E182CC I believe? gm is around 15mA/V as well per triode...
Low power JFET WCF Osvaldo de Banfield Solid State 2 20th April 2012 12:10 PM
What would be the correct output cap for this OTL Headphone Amp? pingfloid Tubes / Valves 26 2nd January 2012 03:51 PM
6E5P Jaime Tubes / Valves 6 10th March 2011 07:17 PM
Humming from WCF but not SRPP Brit01 Tubes / Valves 5 22nd August 2010 08:37 PM
6e5p Vladi59 Swap Meet 0 18th March 2009 07:26 PM
Copyright ©1999-2013 diyAudio
