6e5p WCF headphone amp with no cap! - Page 3 - diyAudio
Old 22nd May 2012, 06:22 PM   #21
TheGimp is online now TheGimp  United States
TheGimp's Avatar
Simulation shows 0.196% THD at 180mVrms. this is predominately 2nd order.
Third Harmonic is down at 4.66e-5
4th is at 8.26e-7. (below -120dB)
I'm using Dmitry's triode mode model.
Old 22nd May 2012, 07:26 PM   #22
mogliaa is online now mogliaa  United Kingdom
mogliaa's Avatar
Sounds promising Steven. Would you mind sending me your circuit so I don't start from scratch?
thanks
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 22nd May 2012, 07:52 PM   #23
TheGimp's Avatar
Here is the circuit and 6E5P_T model in a zip.
Old 22nd May 2012, 08:02 PM   #24
mogliaa's Avatar
Thanks Steven. I thought you simulated what Lars was proposing. I can work from this one (which is same one as I had but with Dmitry's model).
Ale
Old 23rd May 2012, 02:40 AM   #25
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by mogliaa View Post
Hi Bigun,
On the last edition of Morgan Jones' book he found that 6BX7 shows a big variance in distortion so these need to be manually chosen for audio use...
Ale
Thanks - that's a good tip to know about.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 23rd May 2012, 07:11 AM   #26
Think the whole idea of OTL is doubtful as the tubes are working in an unlinear area.
Add a 4:1 transformer after a single 6E5PT cathodefollower(hereticalstyle) and we are talking at least ten times lower distortion. Load is now in the ballpark of .5k. One have to watch the DCRs though, as these contribute to Zout. And is there a suitable transformer available??
You can dump the input transformer but need to keep the CCS to add necessary current.
Old 25th May 2012, 07:09 PM   #27
mogliaa's Avatar
Hi Lars,
Will the classic Sy heretical stage be sufficient? Perhaps need some valves in parallel. Will simulate over the weekend.
Interesting proposal, however, need to check what OT could fit there...
Ale
Old 26th May 2012, 08:49 AM   #28
mogliaa's Avatar
Here we go again. Well, 36mA of anode quiescent current per valve. Need three to get THD down to 0.10% at output voltage of 100mVrms. This is a nice operating point for the 6e5p, and FFT looks clean to me.
Is there a better choice of CCS transistors?
Only cap is input, which could be removed if an input transformer is used.
I think I should breadboard this one and listen to it?
Old 26th May 2012, 08:59 AM   #29
Do you hope to have 6E5Π's that well matched that they ll work well with one CCS?
Old 26th May 2012, 09:07 AM   #30
mogliaa's Avatar
Clearly that is one of the challenges here. Will need to test some and see if I can make a matched trio
Low power JFET WCF Osvaldo de Banfield Solid State 2 20th April 2012 01:10 PM
What would be the correct output cap for this OTL Headphone Amp? pingfloid Tubes / Valves 26 2nd January 2012 04:51 PM
6E5P Jaime Tubes / Valves 6 10th March 2011 08:17 PM
Humming from WCF but not SRPP Brit01 Tubes / Valves 5 22nd August 2010 09:37 PM
6e5p Vladi59 Swap Meet 0 18th March 2009 08:26 PM
Copyright 1999-2017 diyAudio
