6e5p WCF headphone amp with no cap!
Think the whole idea of OTL is doubtful as the tubes are working in an unlinear area.
Add a 4:1 transformer after a single 6E5PT cathodefollower(hereticalstyle) and we are talking at least ten times lower distortion. Load is now in the ballpark of .5k. One have to watch the DCRs though, as these contribute to Zout. And is there a suitable transformer available??
You can dump the input transformer but need to keep the CCS to add necessary current.
Hi Lars,
Will the classic Sy heretical stage be sufficient? Perhaps need some valves in parallel. Will simulate over the weekend.
Interesting proposal, however, need to check what OT could fit there...
Ale
Here we go again. Well, 36mA of anode quiescent current per valve. Need three to get THD down to 0.10% at output voltage of 100mVrms. This is a nice operating point for the 6e5p, and FFT looks clean to me.
Is there a better choice of CCS transistors?
Only cap is input, which could be removed if an input transformer is used.
I think I should breadboard this one and listen to it?
Hey Ale,
The tube has Pamax 8,3W and Pg2max 2,3W. 100V*60mA=6W. So what is the problem?
An input transformer should also be used to get rid of the input cap.
No reason to go into details before you have found the best topology.
