Just wondering if say a 5Y3 will sound different than say a 5R4. With an identical power supply I pulled out a 5Y3 and substituted a 5R4 and picked up about 7volts. I seemed like the 5Y3 had a little better low end punch. I thought maybe the more experienced folk here could lend an opinion.
Joe |
#2 |
5Y3 is a lower performance rectifier than 5R4 or 5U4 because it isn't made for as large a load. You'll get more voltage using a 5U4 in a 5Y3's place. Note: you may overload the rectifier winding doing this! 5Y3 has a 2A filament, whereas 5R4 and 5U4 have 3A, which also reflects their higher current capability, which brings the second point: don't use a 5Y3 in just any 5U4/5R4 circuit!
Unless a few thousand varactor diodes are involved somehow, changing the plate supply voltage will not affect the response. The different supply impedance may affect bass, but it's all more likely in your head. Tim |
#3 |
diyAudio Senior Member
Diode Rp can affect bass response in an audible way especially in deliberately poorly designed PSs such as for guitar amps. With a well designed PS for audio this effect should be swamped. Cheers,
Frank |
#4 |
Thanks Tim and Frank for the responses.
Tim I would never swap a 5Y3 into a circuit that was designed for a 5U4/5R4 circuit. I did however swap a 5U4/5R4 into a 5Y3 circuit for a short time. I was curious as the the change in output voltage and I saw what I was looking for. Frank I swapped the rectifier tube in the (Joel'sLine amp project) and this is where I thought I heard the difference. Granted it may be in my head. This was just a simple RCRC power supply with hum. Joe |
#5 | |
Frank |
#6 |
i believe that when a change in rectifier was made which caused a voltage to drop or raised, the difference that you hear is caused by the change in the operating point.
i could be wrong.
#7 | |
![]() 316a |
#8 | |
However, quite often differences can be heard even when B+ is held constant between different tube rectifiers. Cheers,
Frank |
#9 | |
Tim |
#10 | |
I also conducted similar tests with 12AU7 . Different kettle of fish altogether . The only one I remotely liked was the RFT . For me there is no hope with the 12AU7 , for some it's a lifetime of tuberolling to try to find one they actually like . It's the 'chocolate sauce on everything' syndrome with this tube . If you like 'em it's up to you 316a |
| Tube rectifiers for Dummies | bigjppop | Tubes / Valves | 8 | 17th July 2009 06:04 AM |
| Need DIY Bass Guitar slap effect??Help!! | thomgun_lc | Instruments and Amps | 24 | 25th July 2006 07:59 AM |
| Effect Of Stuffing On Sub Response | Matttcattt | Subwoofers | 14 | 16th November 2004 06:40 PM |
| Beaming effect on polar response at crossover | tiroth | Multi-Way | 13 | 3rd July 2004 10:25 PM |
| Tube rectifiers | NickC | Tubes / Valves | 32 | 7th November 2002 09:10 PM |
