Decoupling DC heater supply between valves..benefit? - diyAudio
Old 18th May 2012, 12:56 PM   #1
6J6 is offline 6J6  Australia
Default Decoupling DC heater supply between valves..benefit?
Hi all,
Think of how you typically decouple preamp stages in a valve audio amp using RC networks set to an appropriate time constant.
Now if you were to apply that to the heater supplies of preamp valves, for each valve, do you think there would be any benefit sonic or other?
Never really thought of any mutual effects of heaters in a power feed chain, irrespective of how clean the DC feed is (regulated or not).
I haven't seen this concept used in any amp and think it would be fun to see if it could lower a noise floor, improve linearity, reduce crosstalk artifacts etc. Would cathode to heater capacitance have any bearing on the common supply?
I've discounted AC heaters even with balance pots as most preamps I think sound better with DC. Yep, controversial comment I know
Any thoughts or ideas?
6J6.
Old 18th May 2012, 01:15 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
If the valves has filamentary cathode (direct heating), and they also acts a cathode, you may decouple them. If indirectly heated, I believe it isnīt needed.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 18th May 2012, 02:53 PM   #3
Hi Osvaldo,
DHT's would definately benefit the most from this idea, as obviously the heater/filament is also the cathode.
I was mainly referring to indirectly heated valves which I use for everything, and especially about heater to cathode capacitance interacting with the supply and other valves.
I think there is validity for both. Can't understand why I haven't seen it on any schematics..
6J6.
Old 18th May 2012, 03:16 PM   #4
I believe definitively is not necessary to decouple them. At audio frequencies, capacitive coupling is small because of the low capacitance and low frequencies. So coupling is very very poor. And in case of high frequencies, at RF levels, it is normally no necessary to use DC at heaters.
But, no think implies that for security or simple pleasure you want to add decoupling, I donīt see any trouble.
Old 18th May 2012, 03:49 PM   #5
DF96 is offline DF96  England
Heater decoupling is used in communications receivers (AC heaters of course). Very unlikely to make any difference for audio, except possibly to inject noise into a signal ground.
Old 18th May 2012, 04:07 PM   #6
100% agree.
Old 18th May 2012, 04:08 PM   #7
Michael Koster's Avatar
I think it's probably best to provide a low AC impedance path from the heater supply to the star ground for common cathode amplifiers. Cathode followers may sometimes benefit from or even require separate heater supplies.
Old 18th May 2012, 04:14 PM   #8
Originally Posted by Michael Koster View Post
I think it's probably best to provide a low AC impedance path from the heater supply to the star ground for common cathode amplifiers. Cathode followers may sometimes benefit from or even require separate heater supplies....
... because they are AF live and DC elevated from ground.
Old 27th May 2012, 07:42 AM   #9
regal is offline regal  United States
For tubes that oscillate like WE417 I found huge improvement by decoupling the heater pins, That heater wire is an antennae.
Old 27th May 2012, 08:26 AM   #10
Hi Regal, what values would you use to decouple?
Transformer choice for DC heater supply? dfro Tubes / Valves 14 10th January 2011 08:46 AM
dc heater supply help milen007 Tubes / Valves 17 21st February 2009 08:42 AM
Simple DC Heater Supply d1camero Tubes / Valves 9 19th October 2007 11:33 PM
regulated DC heater supply jarthel Tubes / Valves 30 29th May 2006 01:19 AM
Any benefit to DC heater on parallel supply rectifier (GZ34)? leadbelly Tubes / Valves 2 13th February 2006 12:00 PM
Copyright Đ1999-2017 diyAudio
