Old 27th May 2012, 07:29 AM   #11
regal is offline regal  United States
started with 200pf which helped but someone on here recommended 0.1uf and they work great, lowed measure thd (soundcard test) as I suppose the tube was wasting power oscillation in the mhz.
Old 27th May 2012, 07:50 AM   #12
Thanks, I'm using a lot of 6AK5 tubes (cos they were free) but they oscillate real easy. Never thought of the heater supply needing decoupling...
Old 27th May 2012, 01:17 PM   #13
DF96 is offline DF96  England
The 6AK5 was designed for UHF amplification up to about 400MHz. It doesn't know that you only want it to work up to about 20kHz.
Failing to decouple the heater supply is unlikely to cause oscillation, except in some RF circuits, as the heater is mostly hidden inside the cathode, but it might spread the consequences of an oscillating valve. The solution is to stop the valve from oscillating by adding stoppers and ensuring that the cathode has a low inductance path to ground.
Old 28th May 2012, 12:15 AM   #14
6J6 is offline 6J6  Australia
Thanks for all the interesting replies, some good points to think about.
Seems that with DHT's it's a definate benefit, and perhaps oscillator tubes used in audio. I'm thinking of my favourite little cheap small signal tube the 6J6, which started life as a mixer/oscillator. It's indirect but I guess we shall see if it makes any difference.
For the sake of a cheap capacitor, why not
Old 28th May 2012, 12:20 AM   #15
Oh, and forgot to say djgibson51, 6AK5 / EF95 is a nice little pentode too. How does it compare to the EF86 in actual use for audio?
Old 28th May 2012, 01:51 AM   #16
I haven't any experience with the ef86, but love the flexibility of use, and clarity of sound of the 6AK5. Nor is it a "hungry" tube. See some of my 6AK5 adventures in the "100 buck amp" challenge
Old 29th May 2012, 08:23 AM   #17
I decouple with 2 (one per leg) 10n ceramic to chassis, at the first valve of the chain.
I have not tried decoupling every socket, but RF interference is shorted to ground once, so I am OK.
Old 29th May 2012, 08:32 AM   #18
Thanks costis.
Old 29th May 2012, 09:58 AM   #19
You are only OK if any RF is at a fairly low frequency, or the heater chain is very short. Short RF here, and a quarter-wavelength away over there it has got stronger!
Old 29th May 2012, 10:27 AM   #20
Well I got it off "Building Valve Amplifiers" and use it.
quarter-wavelength at these distances is around radar frequencies....
Transformer choice for DC heater supply? dfro Tubes / Valves 14 10th January 2011 07:46 AM
dc heater supply help milen007 Tubes / Valves 17 21st February 2009 07:42 AM
Simple DC Heater Supply d1camero Tubes / Valves 9 19th October 2007 10:33 PM
regulated DC heater supply jarthel Tubes / Valves 30 29th May 2006 12:19 AM
Any benefit to DC heater on parallel supply rectifier (GZ34)? leadbelly Tubes / Valves 2 13th February 2006 11:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
