A tube amp that's actually a tesla coil.
Old 18th May 2012, 07:21 AM   #11
costis_n is offline costis_n  Greece
Also, do you enjoy breathing O3?? (ozone)
Old 18th May 2012, 10:33 AM   #12
bigwill is offline bigwill  United Kingdom
I must admit I'm fond of that sweet ozone smell
Originally Posted by MadsKaizer View Post
Hey Bigwill
I have built 7 Tesla coils and one of them was a VTTC, you can see it here Kaizer VTTC I | Kaizer Power Electronics and I will gladly answer any questions you have.
Thanks, that is brilliant
Originally Posted by Michael Koster View Post
Whether the primary is a tuned circuit of uses an oscillator, it is driven at approximately the resonant frequency of the secondary.
This is what I'm still struggling with - the primary coil is generally on the order of 30-100μH, and the secondary resonance is usually in the hundreds of Khz range. The reactance of the primary will be pretty low at these frequencies, tens to hundreds of ohms - certainly not something a tube is happy driving. Will the coupling to the resonant secondary increase this, or must I add a tank capacitor in parallel so the impedance peaks around where you want? (Q could be adjusted to give you a usable range of tuning)
What gets me is I've seen a VTTC design WITHOUT an anode tank capacitor here: Miniature Vacuum Tube Tesla Coil
There is one in the grid circuit, but presumably that's just to set the oscillation freq, not energy storage?
Old 21st May 2012, 10:40 AM   #13
MadsKaizer is offline MadsKaizer  Denmark
You are right about the grid circuit, its only feedback and not a energy storage.
To explain it simple, running a Tesla coil without a tank capacitor will make you able to produce sparks, but not very big ones. With these it is important to have a feedback locked on the secondary frequency.
With a tank capacitor you get much higher peak currents in the primary circuit and you deliver a greater amount of energy to the secondary in shorter time and thus get longer sparks.
A tube amp that's actually a tesla coil.Hide this!Advertise here!
Phonostage with tube moving coil legarem Tubes / Valves 4 13th October 2011 04:42 PM
Air-Core Transformers with applications in Tesla Coil design thadman Power Supplies 2 29th November 2010 01:56 PM
Tesla coil almost killed me! gearheaddruid The Lounge 5 22nd March 2008 09:10 PM
Dual-Coil Choke for Tube Preamp CLS Power Supplies 13 18th July 2005 02:22 PM
COOL STUFF tesla coil! mikee12345 The Lounge 2 2nd September 2003 07:07 AM
