Pre amp output, would this work?
Old 17th May 2012, 06:23 AM   #1
Navyblue is offline Navyblue  Singapore
Default Pre amp output, would this work?
First of all, I am very new in circuit design, if it can actually be called that.
I am building a simple single stage single ended headphone amp, like this:
I am wondering if I can tap a pre amp output from the plate with just a capacitor (the dotted box)? The tube is 6H30. There is a 2200 ohms resistor across the OPT secondary so that it is loaded at all times. I can have a switch at the proposed pre amp out, I imagine it has to be disconnected when the headphone is plugged in.
Would this work at all? Am I better off tapping the pre amp out at the OPT secondary with impedance matching parallel resistor?
Thanks.
Old 17th May 2012, 07:54 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
oh, I thought the preamp would go before the headamp
Old 17th May 2012, 08:07 AM   #3
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
I see no reason why not. Don't forget to add a 100k resistor between the output side of the cap and ground.
Old 17th May 2012, 08:56 AM   #4
and small series resistor ?
not sure why, but aren't there ususally one ?
isolation maybe
hmm, 100ohm ? wouldn't that be a rather small grid resistor ?
and the 10K IT(OPT), wouldn't that very much depend on tube ?
Power(gain) loss from step down impedance ?
Old 17th May 2012, 09:03 AM   #5
why not cathode output, and another gain stage ?
might do with smaller(better) signal trafo ?
Old 17th May 2012, 09:58 AM   #6
I prefer an active preamp at this point of time.
Old 17th May 2012, 10:00 AM   #7
Glad that I can actually come out with something that works.
I sometime see a high value resistor to ground at the output, what is it for anyway? For stability?
Old 17th May 2012, 10:06 AM   #8
You mean a gain stage, followed by a cathode output, and followed by another gain stage?
I considered another gain stage, but unless I commit a serious power tube, I don't get much more voltage swing. And the additional capacitor and triode in the signal path does not seem to make it worth the trouble.
As for the grid resistor, I am actually following a schematic, I don't really know what is a good value.
The OPT is custom made for headphone btw, and I already bought it so it's not open for discussion.
Old 17th May 2012, 10:14 AM   #9
analog_sa's Avatar
It's there to provide a discharge path for the cap. Bad things can happen if the pre is plugged into a solid state power amp with the cap still charged...
Old 17th May 2012, 10:24 AM   #10
Thanks. Glad that I asked, there are many basic things that I have yet to find out.
Btw, what is an appropriate value for the output capacitor. In the V cap website, there is a calculator. With a 50k ohms load, I came out with 2uF. Somebody here has an approximation that goes like capacitor size = 0.1/load impedance , which turns out to be 2uF as well.
Pre amp output, would this work?Hide this!Advertise here!
AV-7000 amp, sub pre-out work from digital in??? Hayden Solid State 2 31st March 2012 12:03 AM
Pre amp output shorted? SimpleMind Analog Line Level 38 24th March 2012 10:43 PM
Will This Pre-Amp Circuit Work benproiii Chip Amps 22 18th September 2010 10:14 PM
Quad 66 pre amp output affordablehifi Solid State 2 16th February 2005 10:39 PM
DC in Pre-amp output Herman Chung Tubes / Valves 11 5th August 2004 11:14 PM
