8x Push-pull KT88 class A in triode mode
Old 26th June 2012, 11:12 AM   #31
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
^hi,
the schematic was adopted from carver's silver seven power amps.....12by7 input, 12bh7 ltp drivers....the kt88's are trioded with a 100ohm/5watt resistor...no global negative feedback used....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 27th June 2012, 03:28 AM   #32
Positron is offline Positron  United States
Hi 22,
A few things to consider off the top of my head.
1) SET with parallel tubes offers Miller capacitance times number of tubes in parallel in SE operation. UL operation offers higher power output than triode and less Miller capacitance. In either case the high frequency response will be reduced, so a fairly low impedance driver is necessary.
2) SET with parallel tubes means more problems with OPT being satuated unless parafeed is used.
3) In PP, the phase splitter is very critical to optimum performance, and difficult to obtain.
4) In PP operation, the same problems exist with Miller capacitance in triode and UL operation as point 1.
5) Grid "stoppers" and screen or plate "stoppers" are very necessary for parallel operation of tubes, as parasitic oscillations will otherwise occur.
Cheers.
Old 3rd July 2012, 01:25 PM   #33
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by Positron View Post
Hi 22,
Cheers.
Thanks for your input. I am still studying possible designs, pros and cons.
1) It will be a PP design, maybe UL topology.
2) Same, will be PP.
3)I am not sure to use a tube splitter, what would be the downside of using an input transformer for creating phase and anti-phase? I have had great results using it to bridge SS amplifiers, and it is easier to wire and has 0 watts of pwr consumption:
http://www.lundahl.se/pdfs/datash/1545a.pdf
4) I will be using PP with 2x or 4x tubes per channel, so there's a chance i'll be paralleling tubes. I am still looking for candidate circuits.
5) A very important point to care for, thanks!
Best regards
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
8x Push-pull KT88 class A in triode modeHide this!Advertise here!
KT88 Parallel Push Pull Xpersephone2 Tubes / Valves 67 16th September 2014 10:02 AM
EL34 in class AB2 triode mode push-pull? ray_moth Tubes / Valves 29 8th March 2009 07:34 PM
KT88 Push-Pull denny9167 Tubes / Valves 9 21st January 2008 07:54 PM
KT88 push pull Hojvaelde Tubes / Valves 5 10th November 2005 06:51 PM
Biasing Push Pull Triode amp into Class A G Tubes / Valves 11 4th November 2002 02:27 PM
