8x Push-pull KT88 class A in triode mode
Old 17th May 2012, 03:01 PM   #11
SGregory is offline SGregory  United States
Not sure you would be carrying it to a bbq would be an option without a tow motor. That would be alot of iron!
Living Life Doing the Waltz in 4/4 meter.
Old 17th May 2012, 04:17 PM   #12
Cassiel is offline Cassiel  Libya
Yes, I don't think he's aware of the trouble ahead.
Doing it as big as we can, just because we can
Can you? We'll see.
Old 17th May 2012, 05:49 PM   #13
Palustris is offline Palustris  United States
Palustris's Avatar
"there's no real reason for so much power, just want to do it because its uncommon"
It is uncommon because it is impractical, costly, and will be severely compromised in sound quality. If you really want to have a lot of power and great sound why not build a PP 845/211/GM70 amp. The first time you melt a meter probe on 1000V will give you a real thrill too.
Old 17th May 2012, 07:42 PM   #14
data is offline data  Australia
I really don't see why you guys have such an issue with this, given he has hungry speakers!
You need headroom for transients.
Old 18th May 2012, 01:14 AM   #15
chrish is offline chrish  Australia
chrish's Avatar
I think the issue is he wants to do something 'different' that is not normally done, without realising that there is normally a good reason for it not being done. On top of that, he wants someone else to provide all the answers so he can have a unique amp.
Also, the design process is all *** backwards. 'I want 8 KT88 in triode and use these regulators I have already purchased, I want it to be unique and I want you to design it for me' is going to end in tears. Perhaps a statement of 'I like this KT88 SE amp I have, but I want to drive these 87dB speakers' is a better design starting point. Others will probably had a similar design goal and you will be able to look to their solutions for a suitable design.
In short - doing something different is great if you have the skills and resources to do it yourself. If you don't, and you want a solution presented on a platter - then look to a tried and tested design.
Chris
Old 18th May 2012, 01:43 AM   #16
yoaudio is offline yoaudio  United States
diyoAudio Member
yoaudio's Avatar
Here's your 8- KT88 amp kit-
Build a pair of M-125 Mono-blocks from Bob Latino.
125 watts from 17 Hz to 32 KHz at less than 1% THD in ultralinear - 65 watts in triode.
Old 18th May 2012, 01:55 AM   #17
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
Eight per side, why not twelve?
Here you go, and good luck.
schem-input-driver300wjan06
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 18th May 2012, 08:28 AM   #18
costis_n is offline costis_n  Greece
Originally Posted by regiregi22 View Post
Yeah, I know it is a very different beast (From what I've read. I haven't heard any PP yet), but I wanted to keep it as close as possible regarding:
-Triode mode
-Class A1 operation
-No feedback
-Conservative rating: Many tubes means same power, but long life for them.
I like your idea of more tubes in a SE setup, I didn't know it was possible to use more than 1 tube in SE to have more power. As it seems, I am a totally newbie in the tube world. Still much to read and learn, on the way
Nope, not close enough. If you like SE, it has to be SE. How about 4XGU50 triode per side? (35 watts per channel more or less)
Old 18th May 2012, 09:16 AM   #19
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i've done 8 KT88 trioded per channel: this baby eats 450watts idling:
-Triode mode
-Class A1 operation
-No feedback
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 18th May 2012, 10:37 AM   #20
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Can you? We'll see.
Then we should change "Doing" by "Trying"? Trying, just because we can.
In fact, I though I was asking for someting quite common. 4x tubes per channel in triode mode? I am a tube noob, but, is this REALLY a so strange thing? I am not needed for 1k watts, but something in the 30W-80W ballpark. Something that can stand up against a plain gainclone powerwise, nothing more.
I may admit I thought it was a bit exaggerated to think of 8x tubes per channel, or even arrogant. Now I am sure. Excuse my ignorance.
Chris
In fact, I though that a 4 tubes amp operating in triode wasn't a so "unique" thing, that's why I was asking for proved and tried designs, in order to compare them and learn how do they work. Why do values change between similar end designs. Why and how are things done in each case.
Chris
As I said.... that's really what I was asking for. I know that my end build will be unique in the sense that this is DIY and no two designs are exatly the same. But having some directions on already proved designs can give me some ideas on how to combine them.
Every project I have ever started never ended as the idea it started to be, so these are just my thoughts, not a final fixed idea. If it were, I were not asking for advice.
Thanks yoaudio for your valuable opinion, that's what I was asking for. My last one project was in the kit form, this time I would like to source components by myself. But that's the point of desing I was looking for.
Tony, I really like your project. A separate PSU when going so big is an interesting approach. I would have gone with a closed enclosure. Coming from the SS world, one thing surprises me is the common tube builders approach of placing components outside the case. I can understand it's done for valves for heat reasons, but seems to me that its too far common to place other unnecesary (and dangerous!) components outside the enclosure. For example, in your desing, I would have gone with the PSU in a closed case. That way it seems less obscene, fragile, and the tube module can be piled on top of it. But that's just my side of view
Great and impressive design all in all!
Thank you very much guys for your advices. They help my feet to keep on the floor.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
8x Push-pull KT88 class A in triode modeHide this!Advertise here!
KT88 Parallel Push Pull Xpersephone2 Tubes / Valves 67 16th September 2014 11:02 AM
EL34 in class AB2 triode mode push-pull? ray_moth Tubes / Valves 29 8th March 2009 08:34 PM
KT88 Push-Pull denny9167 Tubes / Valves 9 21st January 2008 08:54 PM
KT88 push pull Hojvaelde Tubes / Valves 5 10th November 2005 07:51 PM
Biasing Push Pull Triode amp into Class A G Tubes / Valves 11 4th November 2002 03:27 PM
