Cap or resistor - diyAudio
Old 13th May 2012, 05:30 PM   #1
xecluded's Avatar
Default Cap or resistor
Does anyone know if the item attached in the picture is a cap or resistor. Thanks.
Old 13th May 2012, 05:43 PM   #2
It's a film cap from the 50's...
The stuff you don't know always humbles us.........
Old 13th May 2012, 06:04 PM   #3
devilsindetails's Avatar
Yup...A bumblebee cap it is....for more info on these and how to determine values based on the colour codes see here:
Edwin Wilson's Bumblebee Capacitors
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 14th May 2012, 11:21 AM   #4
xecluded's Avatar
Cool. Many thanks for the info. That's a big help :-)
Resistor before or after cap? fatmarley Multi-Way 5 6th May 2009 04:26 PM
Resistor instead of Cap in HK347 Stream Solid State 9 22nd April 2009 12:48 PM
Amp Sensitivity, cap or resistor? Can I do this? silentblackhat Solid State 8 15th February 2006 04:47 AM
Importance of Cap/Resistor type Dwiel Chip Amps 0 13th December 2004 08:01 PM
why a cap and resistor at output of leach? Wagener Solid State 2 13th August 2004 07:08 PM
Copyright 1999-2017 diyAudio
