Hi
I am going through KT88 Push Pull design , I have chosen my operating point as Ua=475 , Ia=70mA , Zaa=9k7. It should give me operation mainly in class A. Please have a look at my loadline: Attachment 282158 As a driver I am going to use triode strapped D3a in SE grounded cathode circuit plus LL1660 interstage transformer .Another option is LL1660 interstage transformer preceded by pair of D3a in LTP circuit , phase split by input LL1544A transformer . Let's cut to the chase , to drive pair of KT88 with no grid current I need 2*53V=106V peak-peak (~34.5 VRMS) , lets assume that my interstage tranny has step down ratio 1:1.125 .According to that I need 38.8 VRMS from SE triode strappeed D3a. As D3a has gain of ~77 , it means that 500mVRMS from source drive my amplifier to full power. Assuming that standard CD puts 2VRMS output , what will happen when I go above 500mV? Regards |
#2 |
You will get clipping. To stop this, use a volume control.
#3 |
Hi
What value of input signal would be the best then , 500mV seems to me bit low Any comment about choice of my operating point? Regards |
#4 |
If 500mV is what you need for full output, then 500mV is the correct amount. Why does it seem low? Power amps used to need even less than that. The trend to many volts input is a recent one, and rather baffling.
#5 |
It looks to me like it will start clipping quite early , giving not much volume adjustability.
Next question , how many amps/volts on the secondary of output transformer to drive comfortably wide range of speakers (from 85-92 dB)? |
#6 |
It depends on the size of your room and how loud you like your music. You are asking how long a piece of string do I need - I would ask what you want to do with the string.
#7 | |
#8 |
Hi
From what I have read, negative feedback is not an option when it comes to transformer interstage coupling.But I might be wrong , I know very little about IT coupling - trying to learn . There are 2 circuit options: D3a input stage-page-001.jpg no need for ltp in this case , transformer does phase splitting. and 2nd option: Circuit.JPG in this case splitting is done on the input ,second transformer does interstage coupling.As you can see it uses ltp (I am planning to use ccs in the tail ), and here is my question, if grids are fed with already split signal , what would be gain of this stage? Coming back to my loadline , any suggestions? I use quite high tr impedance , instead of recommended 4k5-6k6 , I wonder why is not commonly used ( it gives so much of class A , power is low if compared to power dissipated in anodes ) , am I overlooking something? I wonder if my operating point is right ,my voltage is quite high and going on characteristic to the right I am not sure whats happening there , as I have no curves below -60V.This makes me think if I have symmetrical swing on the negative part of signal . Last edited by slav; 14th May 2012 at 09:54 PM. |
#9 | |
At 475 B+ and 70ma Iq, OT 9700 gives about 26W total, although it gives 34W class A, but I think you'll only get 26W. OT 8000 gives around 28W total, all class A OT 7000 gives around 30W total, with about 24W class A. and so on.........this trend continues with lower impedance output transformers |
#10 |
It does confirm my assumption , higher load seen by tubes it goes deeper into classA.
Your results for 475V are interesting , my interpretation is that there is still more of classA available if grid goes more negative but grid input signal is restricted by Vg=0V. Question is how does it look like in tetrode classAB operation ? |
| Which KT88 PP and which Transformers? | Dave S | Tubes / Valves | 66 | 8th January 2012 04:37 PM |
| Stereo Driver PCB for PP Amp (EL34/KT88)? | Cobra2 | Tubes / Valves | 8 | 17th December 2010 09:50 PM |
| Kt88 Pp | barossi | Tubes / Valves | 2 | 24th December 2008 05:55 PM |
| Three PP KT88 designs. Which one ... (please;-) | WE91 | Tubes / Valves | 28 | 2nd January 2008 09:16 AM |
| My new pp KT88 design | baggystevo82 | Tubes / Valves | 41 | 16th May 2005 01:02 PM |
