Replacing 6922 with 6FQ7 in Conrad Johnson ET3 preamp - diyAudio
Old 12th May 2012, 07:24 AM   #1
Send a message via MSN to ronenash
Default Replacing 6922 with 6FQ7 in Conrad Johnson ET3 preamp
Hi all,
I trying to find out if I can replace the 6922 tube inside my CJ ET3 preamp with a 6FQ7. Anyone tried this? I know the 6FQ7 should be more durable but requires more fillament current which should not be a problem since the ET3 power supply is designed to support 3 additional tube filaments for the phono section which I do not have installed.
Any thoughts would be appreciated.
ronenash
ronenash
Old 12th May 2012, 10:04 AM   #2
DF96 is online now DF96  England
6FQ7 and 6922 are quite different valves which happen to share the same pinout. Any circuit properly designed for one would be sub-optimal with the other. If it sounds 'better' with the wrong valve in, then either you like listening to distortion or the original design was poor.
Those are my thoughts.
Old 12th May 2012, 01:42 PM   #3
Thanks DF96. This makes sense.
ronenash
Help! CONRAD JOHNSON DF1 CDplayer-preamp dray177 Digital Source 56 18th March 2014 12:10 PM
Conrad johnson Preamp Volume Rajkumar_ Tubes / Valves 1 3rd August 2012 07:32 PM
Upgrading the Conrad Johnson Premier Fourteen preamp Tino_diy Tubes / Valves 10 12th March 2012 02:13 PM
Conrad Johnson ART preamp question. robmil Tubes / Valves 24 16th February 2011 02:59 PM
Conrad-Johnson PV6 Preamp paulcurrie Tubes / Valves 3 17th April 2004 07:11 PM
Copyright 1999-2017 diyAudio
