PP GU50 triode strapped project - Page 4 - diyAudio
Old 12th May 2012, 03:14 PM   #31
jane is offline jane  Norway
jane's Avatar
Originally Posted by LAZAROIU View Post
Raa = 4000ohmi, is seen and calculated as an OT like normal and then will distribute a 1/4 anode and katod tasks for the two final floor tubes.
Be sure OT is running PERFECT!
But everyone thinks it sees fit, so I was thinking and it seems that everything is OK!
I'm not sure I understand you, but:
In a normal push-pull stage each output tube sees 50% of the windings that is Raa/4 (in class B). In a unity stage each tube sees 100% of the windings (anode + cathode windings) that is Raa. If you want the tubes to see the same reflected load in a unity stage as in a normal push-pull stage the unity-OPT should be Raa/4 (where Raa is the anode to anode load in a normal pp stage).
Jan.
Life is hard - Then you die.
Old 12th May 2012, 03:44 PM   #32
Jan.
Can we not understand, but I did a test simulation result for LTC and have equivalent Raa 3700ohmi results of pictures, but the schematic is made ​​and practical.
Of course I made a proposal, but you can improve all.Proposal another configuration transformer, with some drawings and can get along better.
LTC simulation images below to Raa = 3700 ohm (equivalent), everyone on this forum can verify this.
Thanks for your attention!
Old 12th May 2012, 04:51 PM   #33
rectify and apologize:
it is: Fourier analysis,not Forier.
Bode diagram ... and if it is useful ...
Old 12th May 2012, 04:55 PM   #34
Hey LAZAROIU,
Why not share your *.asc with the rest ofus?
Old 12th May 2012, 05:05 PM   #35
Originally Posted by revintage View Post
Hey LAZAROIU,
Please escuse me, i dind't understood you're question. Do you want a scheme in format ".asc", for a simulation in LTC? or do you want something else?
Old 12th May 2012, 05:08 PM   #36
Exactly as I said. But is not important as I am almost ready with the LTSpice drawing. I can share that one instead. What is the primary inductance of your OPT?
Old 12th May 2012, 05:22 PM   #37
I will post the scheme in format ASC, without considering it perfect. It depends on the models of the components from LTC librarys. If you think there is something to change, please feel free to share. (of course in format ASC)
File Type: asc GU50 UTC 20W-PREAMP TUBURI RUSESTI varianta DIY .asc (8.1 KB, 177 views)
Old 12th May 2012, 07:32 PM   #38
Hey,
Have corrected a few errors and used Koren and Bench´s models that are reliable.
You will have to work with the working points as it´s not up to your specs.
The concertina must have higher Ua to work properly, it now is in the ballpark of 50V.
I am not fully aware of how the SRPPs with 27k on top works? Also they seem to run on very low current, 1,5mA.
The GU50 ran on ca 40mA but should maybe run ca 100mA/tube, A knows.
The transformer inductances where much off. Use 2.5H for the primaries and .08H for the secondary to get 4k/8. Gives you a low 40H primary but that´s good enough for initial sims. If you go for 5.55H, secondary should be 0.18H. 5.55/0.048 is ca 15k/8. But maybe strange things happen when you go with cathode windings?
Also some Spice-commandos should be adjusted.
Old 14th May 2012, 09:10 AM   #39
FrançoisL.'s Avatar
Send a message via Skype™ to FrançoisL.
Originally Posted by Vincent77 View Post
François: Lazaroiu's schematic uses a special transformer with windings for cathode feedback, I don't know if Lundahl makes such transformers... There are some very good such toroidal transformers made by Menno van der Veen: Specialist Range Output Transformers
Vincent,
Thanks for the link.
Now, I must say, and maybe it's a novice reaction, that to purchase "special" transformers for a project that I don't know if it will please me or meet my expectations worries me a little bit.........
But maybe I should not?
François.
Old 14th May 2012, 11:36 AM   #40
Here is my version of GU-50 PP triode:
Single ended driver stage and cathode windings to keep the output impedance low (enough) without the means of gNFB.
Should be finished during the summer..
Wow that should take care of the drive problem! I am eager to see your measurements when it is done!
E180F triode-strapped. jim Tubes / Valves 31 26th December 2014 01:19 PM
OPT PP for GU50 Triode ? pwan Tubes / Valves 0 13th March 2011 12:30 AM
6JC6 triode strapped? Bing Yang Tubes / Valves 4 21st February 2009 10:59 PM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 01:36 AM
Recommendations needed for designs of PP pentode strapped as Triode percy Tubes / Valves 24 22nd October 2004 10:03 PM
Copyright ©1999-2017 diyAudio
