popping & crackling noise from restored valve AM radio
Old 9th May 2012, 03:20 PM   #1
budkor is offline budkor  United Kingdom
Default popping & crackling noise from restored valve AM radio
Hi All
Last year, I restored an old valve radio from 1950s. It was not working when I got it, but when I recapped all the original paper capacitors to new ones, it started working.
It is AC Mains powered, and sounds quite good - and it is still working well. But when switched on, and then after about 4 hours constant receiving AM stations, it starts sounding popping and crackling from the reception.
What could this be? Where should I look to sort this problem? Thanks for your info and advice.
Old 9th May 2012, 03:58 PM   #2
M Gregg is offline M Gregg  England
Originally Posted by budkor View Post
Hi All
It could be a lot of things..
The first easy one is, is it still their with the volume turned all the way down..If it is then chance is either PSU caps or leakage in the output stage possible coupling cap. If its gone when the volume is down then its in the reciever stage..again possible coupling cap..
Might be easier with a schematic..
Sorry its a bit vague...
M. Gregg
Old 9th May 2012, 04:04 PM   #3
banat is offline banat  Serbia
It is usually start crackling and popping only in late afternoon and evening time ?, but never in the morning time ?
Did you replace main rectifier elko ?
Old 9th May 2012, 04:13 PM   #4
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Check for a false contact in a tube, or in a tube socket. Try to strike the tubes with a short piece of plastic or wood, then listen the sound it makes. Also, check if it is not an external interference.
Luck!!!
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 9th May 2012, 04:29 PM   #5
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
I once had an old Zenith radio which developed similar crackling noises.
I traced the problem to the IF transformers. Inside the transformer cans, Zenith had designed fixed capacitors. The capacitors were made up of a pair of flat metal plates with a thin sheet of mica between the plates. The mica had deteriorated and the two metal plates had started to arc through the mica.
I was able to replace the mica with a thin sheet of teflon.
Frank
Old 9th May 2012, 04:41 PM   #6
Arcing? There are few RF volts across a IF coil winding. Surely, they make false contact and then introduced noise, but arcing?? Mmmmm....
Old 9th May 2012, 04:52 PM   #7
Yes ... arcing. Zenith designed the radio so that the IF tube plate current went through the transformer primary. Strange design but it did work for many years.
Frank
Old 9th May 2012, 04:53 PM   #8
simon7000 is offline simon7000  United States
Yes but lots of DC!
I would tap the 35W4 (35Z5 in older versions) tube as that is most likely to be the problem. Next try the 50C5 (50L6)
Also look to see if any of the tubes are glowing red on the plates.
FB we cross posted!
Old 9th May 2012, 05:43 PM   #9
No, no and no. The circuits gives no DC voltage across primary winding, as the logic and common sense tell me. So, no voltage = no arc.
Old 9th May 2012, 05:49 PM   #10
The original arc may have been from the primary to the grounded can.
The mica showed a few holes.
Whatever ... it did arc through the mica. As you can see on the schematic, I marked "REP" to indicate that I had replaced the mica insulator.
Frank
popping & crackling noise from restored valve AM radioHide this!Advertise here!
Help needed, Primare A10 crackling and popping. Brillegeit Solid State 8 11th December 2011 10:45 PM
Popping noise from sub?Could it be the amp? tcsounds3hp18 Car Audio 0 2nd June 2011 04:34 AM
crackling noise in crown amp ampcabinets Solid State 4 25th April 2011 09:35 AM
popping crackling distortion that clears up after 2 mins Help!! Puggie Solid State 7 11th October 2006 11:13 AM
Old valve bass amp crackling Kimblea Instruments and Amps 4 27th August 2002 01:57 PM
