Aikido 9 pin All in One Build - Page 21 - diyAudio
Old 20th July 2012, 06:17 PM   #201
Davec113's Avatar
Originally Posted by mattmcl View Post
Yup, it takes a good 10 minutes to warm up, and gets really good after 20. I'm super busy this weekend, maybe some night next week?
Sure, I should get the resistors in early next week. They aren't going to be super easy to change out because I used those big 25V electrolytics for the heaters instead of 16V, so I need to take the PCB out and solder them to the top of the PCB... I'll text you when its ready.
Old 24th July 2012, 05:47 PM   #202
Davec113's Avatar
Mouser was fast and I replaced the resistors yesterday, now the heater voltage is ok and the preamp is finished! HV is a little high at about 330V but I'm ok with that.
Thanks for all the advise and help from everyone who has contributed to this thread!
Old 25th July 2012, 04:06 AM   #203
mattmcl is offline mattmcl  United States
I have two pairs of outputs on my 9 pin, wired in parallel. I want to convert one of them to summed output for a subwoofer. I suspect I need to wire in some resistors- does anyone have suggestions on values?
Old 29th January 2013, 04:05 AM   #204
ClefChef's Avatar
Here's my version of Aikido. It uses 6N1P-EV and 6N6P tubes.
B+ 220V, 6.3V heaters, cathode resistors - 430R, transformer - dual primary, secondaries 250V, 2x7.5V (in parallel for 4A).
Sounded excellent while in my possession. Building another one, this time I intend to keep it. Will post pics later.
Old 29th January 2013, 05:12 PM   #205
Loren42 is offline Loren42  United States
Outstanding execution!
Old 29th January 2013, 05:58 PM   #206
Nice work. Wait until it burns in. Mine really started to shine after 50 hours or so of use.
Old 11th March 2013, 05:29 AM   #207
ClefChef's Avatar
Yet another build...
Old 12th March 2013, 04:10 PM   #208
bondul is offline bondul  United States
Hi ClefChef, Could you tell me what transformer that you use? And where did you get it from?
Old 12th March 2013, 05:30 PM   #209
ClefChef's Avatar
ebay 250v + 7.5v, endbells from edcor.
Old 19th April 2013, 04:35 PM   #210
ClefChef's Avatar
Finishing another Aikido, this time with elevated AC filaments. Initial test show that this is the path worth taking - less heat, less load on transformer, and absolutely no hum, plus it sounds great.
Transformer - Edcor dual primary, 250V @ 200ma + 6.3V @ 3.5A secondary. B+ adjusted to 240V with 230V at the anodes. Tubes 6n1p and 6n6p, cathode resistors - 330R so the tubes are biased for a bit more current.
I had to cut some traces in order to do elevated AC filaments. It would be just great having such option ready on the board, something JB could probably work into his next design.
Now it is time go start fabricating that chassis.
FS: Aikido Dual mono 9 pin version Kit sachi Swap Meet 2 30th May 2010 07:05 AM
Use 9 pin Aikido PCB kit or buy 8 pin ? Renron Tubes / Valves 6 25th November 2007 05:52 PM
JB Aikido Pre 9 pin kit Renron Swap Meet 1 20th November 2007 08:51 PM
what 8-pin tubes would you suggest for an aikido preamp? jarthel Tubes / Valves 3 5th March 2007 11:54 PM
Low gain 9-pin tubes for Aikido? gurevise Tubes / Valves 8 3rd January 2007 12:51 AM
Copyright 1999-2017 diyAudio
