Old 9th May 2012, 07:00 PM   #11
Scott,
You nailed it. I'll be studying Steve's site for a while now. Thanks for your help!
JW
Old 9th May 2012, 07:25 PM   #12
This is useful also . Circuit principles apply to hi fi also . How we see things is often refereed to . Excellent description of SRPP .
How to design valve guitar amplifiers
Old 10th May 2012, 01:02 AM   #13
boywonder's Avatar
and Patrick Turner's education/DIY pages...
loadmatch4-pp-beamtetrodes
Old 10th May 2012, 12:08 PM   #14
I worked through Patrick's guide but I don't have confidence in my results. The curves I have show bias voltages from 0 to -70, the data sheet for the KT88 suggests a bias point of -75 volts. Does anyone have a set of curves for the KT88 with a wider range of bias voltages? Have I made a mistake?
JW
Old 10th May 2012, 12:20 PM   #15
One way to do is to set bias at - 100 V ( g1 ) and gradually work down . Have a 10 R resistor at the cathode so as to read current (V/R = I ) . Don't go above 70 mA I would say . We did it that way at college . We had to plot the curves and say which was best and why . You can use a spectrum analyzer to see the results ( cheap one , freeware perhaps ) . A KT 88 should give about 1% distrotion I suspect . Set HT to about 400 V . Smoothly reducing harmonics will say you got it right . Real KT 88's are not all the same . I suspect JJ are different and need tweaking . Also one can then use any similar tube as you know how . The people who did it first did it this way in the 1920's . Always fit a grid stopper ( 1 K is safe usually , no magic it is a RC filter ) .
Good luck with it .
Old 10th May 2012, 12:48 PM   #16
Nigel,
I am still at the pencil and paper stage I am trying to learn how to plot load lines on plate curves. The bias voltage given on the KT88 data sheet is -75 V but the plots of plate current vs bias voltage I find only go up to -70 V. I have read that I only want to put about 50 mA on the cathode to get full power out of the tubes. Am I confusing two different values? Is the bias grid voltage shown on the plot the DC offset to allow a full swing of the signal input voltage? If this is the case I only need a negative bias of one half of my peak to peak drive voltage, true? The cathode bias I can set independant of the grid by say using an LM317 twisted into a constant current source of 50 mA. Am I close to understanding what is going on here?
JW
Old 10th May 2012, 01:26 PM   #17
boywonder's Avatar
For class AB1 operation, yes.
Old 10th May 2012, 01:39 PM   #18
Nigel,
JW
I can never get my head around them . I was taught by Sid Smith the designer of Marantz amps . He gave up . He agreed my way works . Very nice man was Sid . Sid used LM317 for HT smoothing . It was arranged to work at 400 V and was a famous modification . I always would use cathode bias as it adjusts the KT88 as it ages . Sid always triode connected his amps at home . Sowter in UK make transformers about as good as SIds .
Old 10th May 2012, 01:54 PM   #19
Nigel,
I would like to see how to make LM317 regulate HT voltages, do you have a schematic?
JW
Old 10th May 2012, 01:59 PM   #20
SY's Avatar
Search this site for "Maida."
If there's a sucker born every minute, where do the rest of them come from?
With a little help... KT88 PP UL Amp Herr Grau Tubes / Valves 105 15th January 2013 03:02 PM
PP-UL amp with KT88 misterno Tubes / Valves 1 27th July 2011 04:47 PM
modifying kt88 pp ul amp iorga Tubes / Valves 25 6th March 2010 07:29 AM
My new pp KT88 design baggystevo82 Tubes / Valves 41 16th May 2005 01:02 PM
Possible to make a KT88 PP UL schemat OTL ? Layberinthius Tubes / Valves 3 5th February 2004 02:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
