KT88 PP UL Design Help Needed
Old 11th May 2012, 12:44 PM   #31
pieter t is offline pieter t  Netherlands
Originally Posted by nigel pearson View Post
What about the Russian version GU 50 ? It is worth a look . It was what the Germans came up with about 1942 and think was called a Ray Pentode . Time is running out to buy these . Telefunken LS 50 and Chinese FU 50 also .
GU-50 - Wikipedia, the free encyclopedia
-50
Check Wavebourn's posts at these pages; he is the GU50 specialist.
Old 11th May 2012, 12:46 PM   #32
nigel pearson is offline nigel pearson  United Kingdom
ECC 81 and EF184 are not often thought of to drive KT88 ( 6550 ) . They are possible options . EF184 in Long tail pair perhaps . I don't get involved in PP so out of my depth after that . Look at Quad 11 and see if it can be scaled up . Over to someone who would know on that .
I am looking to buy some KT 88 . I don't want to pay silly money and would use EL156 if I did . JJ is out I think .
http://www.hifitubes.nl/weblog/wp-co...nken-el156.pdf
Old 11th May 2012, 01:19 PM   #33
limono is offline limono  United States
New Quad II forty by TdP which I was checking after it was blowing tubes runs them at 390-400V 100mA in cathode bias circuit . You need Penta Labs Kt88's with ~50W dissipation rate to run in High Power Circuit. Don't forget to confront your design with well regarded circuits. Personally I'd try Allen Wright (may he rest in peace) PP-2 amp.
Old 11th May 2012, 01:23 PM   #34
I think 400 V and 70 mA wise ?
Old 11th May 2012, 01:28 PM   #35
Penta labs KT 88 . Thanks . The plate dissipation is exactly what I wanted to know .
Modern Penta Lab KT88 Vacuum tube.MOV - YouTube
Old 12th May 2012, 11:52 AM   #36
Default KT 88 tester
I think this would work OK as a tester ? In a wood or plastic enclosure as it is not isolated . Various valves could be tested and data kept .
For USA I guess a capacitor fed doubler would give the same ?
Put a high grade input signal transformer on it and you would have an amplifier . Safety will be OK then if careful . NE 5534 op amp or boosted OPA 604 would drive it . I have tried something like this in the past built for me by my brother . I felt a mains transformer offered advantages sonically .
The 6V is a switch mode PSU for simplicity ( 6.3 V ) . The -6V bias switch is to lower the KT 88 into a lower bias . That would I guess make an ideal standby switch if an ideal voltage was found ( run from a comparator perhaps with a 1 hour flip flop action ) ? Please improve this idea if you can .
Stontronics 6V 2A Desktop Power Supply Unit T2319ST
Old 12th May 2012, 02:34 PM   #37
Default Sid Smiths circuit for Marantz 7 C and others
I was asked for this . As far as I know this was originated by Sid . I have heard it and it is good . Remember back then LM317 was very exciting .
DIY Test Equipment for Audio and Ham Radio Enthusiasts
http://community.klipsch.com/forums/...rantz%207C.pdf
KT88 PP UL Design Help NeededHide this!Advertise here!
With a little help... KT88 PP UL Amp Herr Grau Tubes / Valves 105 15th January 2013 03:02 PM
PP-UL amp with KT88 misterno Tubes / Valves 1 27th July 2011 04:47 PM
modifying kt88 pp ul amp iorga Tubes / Valves 25 6th March 2010 07:29 AM
My new pp KT88 design baggystevo82 Tubes / Valves 41 16th May 2005 01:02 PM
Possible to make a KT88 PP UL schemat OTL ? Layberinthius Tubes / Valves 3 5th February 2004 02:59 PM
