...line powered...
Never easy sorting that with "amphibious" equipment though.
the wires are much clooser to you with headphones, I have yet to see a audio output xfmr claim "double insulated" construction
while as long as the headphone insulation/air space is fine you won't have problems - there is little question that the safety story is less compelling with heaphones powered from lethal supply V on your head vs the same powering speakers 10 ft away from your listening position
OTOH, speakers have exposed connections designed for your thumbs. You might even try to tighten them both at once. That's why speakers, and headphone leads, should always be grounded, and the amp should be appropriately fused.
Of the OTL I understand. Of the SET I do not.
Same point, more or less, taken a little further. I don't thing OTLs have ever been legitimate, BTW.
Apart from the adoption of some SS ancilliary circuits, it seems that a great deal of the effort devoted to valve amps post-RDH4 has been to cope with modern recordings, sources, and speakers. This largely boils down to reducing output impedance, which in turn translates to a struggle to reduce OPT winding ratio.
The relatively high impedance of headphones allow a reasonable turns ratio, just about, and low bass is possible without losing the top end.
- Tubes / Valves
- Advice sought on thermionic headphone amp
