Advice sought on thermionic headphone amp - Page 3 - diyAudio
Old 7th May 2012, 05:43 PM   #21
DF96 is offline DF96  England
I think the OP realises that vibrator power supplies may bring problems, but don't swamp him with objections. He knows the sound could get a bit muddy, but he needs to do the best he can with his particular requirement for portability. When immersed in the music he still wants to hear air around the individual instruments.
Old 7th May 2012, 05:46 PM   #22
Simon B is offline Simon B  United Kingdom
Originally Posted by jcx View Post
..the OP schematic is a 4/8 Ohm loudspeaker amp with a R divider on the output for a headphone - lots going to waste there - especially for a battery powered project...
Yes, that is wasteful, I'd presumed the resistor divider shown on the original schematic was just for those wanting dual-use phones and speakers. I did intend to use an appropriate OPT and will probably wind my own, as tar-potting doesn't seem to be available as an option now.
...mechanical vibrator supplies are considered antiquated for good reasons - today the EMI from the mechanical contact opening is unacceptable; size, noise and efficiency can all be improved hugely with modern DC-DC SS designs with integrated chip controllers
I think a good many things that we still enjoy using are considered antiquated by some - including valves in audio equipment. I was told so in no uncertain terms by a university professor - though I don't share his point of view.
I hope to be able to deal with EMI issues to my own satisfaction. Contact breakers were used for many decades in car ignition and suppression was usually quite adequate, with the exception of boy-racers with copper leads and no resistor plug caps.
I'm still keen to hear from members regarding any practical advice they might have on construction issues relating to this particular circuit.
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds.
Old 7th May 2012, 06:04 PM   #23
M Gregg is offline M Gregg  England
Just so we get the correct idea..
Is this circuit submersible or amphibious?
M. Gregg
Old 7th May 2012, 06:17 PM   #24
jcx is online now jcx  United States
if you're winding your own ouput xmfr then I assume impedance scaling is in order
which then opens up tube choice - small signal tubes save doubly by using less heater power which quickly becomes a limitation with only ~ 1/2 Wrms audio power output requirement
car radio noise floor requirements are abysmal, "audiophile" headphone listening would require < ~ 20 dB SPL out of the headphone
vibrator supply operating frequency in the audible range makes the passive filtering requirement costly
Old 7th May 2012, 06:28 PM   #25
M. Gregg
Well the title says "amphibious", so I was going with that...
Old 7th May 2012, 06:36 PM   #26
Is the battery carried back pack or in a vehicle?
M. Gregg
Old 7th May 2012, 06:49 PM   #27
M. Gregg
Something like this was what I had in mind:
Vehicle
Though I have to say that in the light of the comments I've received on here - thank you all by the way - I'm beginning to think that the design of this circuit is quite devoid of any consideration of the basic requirements of its stated purpose.
On a positive note, I understand that such vehicles are usually equipped with alternators, which might be helpful wrt the power supply requirements.
Old 7th May 2012, 07:01 PM   #28
Vehicle
I think its important to understand that if you are looking at creating something to get you the old WW2 feel..the weight was incredible..and that was just the set not battery as well...I have tried one for fun..
If you are thinking New ways to do it thats a different thing..
The circuit as it stands in the 1st post just seems to me like a normal tube amp..car radios had different tubes and were not the normal standard 9 pin we all know..
Some old equipment was very intricate..and very complex..
So I think it depends what you are doing.
M. Gregg
Old 7th May 2012, 08:34 PM   #29
....The circuit as it stands in the 1st post just seems to me like a normal tube amp..car radios had different tubes and were not the normal standard 9 pin we all know....So I think it depends what you are doing...
Well I thought that a "vacuum tube one-port class A amplifier - headphone amplifier amphibious circuit", as per the schematic page's title sounded as like something unusual, and possibly fun, one way or another....
It certainly does seem that it might not be the best circuit for the job, in the many ways mentioned so far on this thread, and also that the voltages involved are positively dangerous (the design indicates the negative rail to be grounded). But I believe it to be possible to catch fish en masse by passing electrical current through water, so perhaps the design might be of use to audiophile fishermen wanting bigger catches?
Old 7th May 2012, 08:46 PM   #30
I suspect you need a decent Chinglish translator to discover what the person who uploaded that circuit thought he was saying.
Advice sought on Class.T Amp for HTPC DanielPool Class D 0 31st July 2010 04:20 PM
Advice sought on medium power triode for tube headphone amplifier rjm Tubes / Valves 13 16th May 2010 04:05 AM
New Cabinet Opinions & Advice Sought Thomo Full Range 8 30th December 2008 11:03 PM
Woofer advice sought cs Multi-Way 7 29th January 2007 09:08 PM
HiFi Advice sought Gina Everything Else 80 11th December 2002 02:19 PM
Copyright 1999-2017 diyAudio
