12b4 bass rolloff problem - Page 5 - diyAudio
Old 21st August 2012, 04:38 PM   #41
zigzagflux's Avatar
Just your standard depletion mode cascode - same as what many others use on this forum.
Old 21st August 2012, 05:24 PM   #42
artosalo's Avatar
Correction to my earlier post.
Zeners will work as a stabilzer with lower current than LEDs do.
Old 13th December 2012, 06:50 AM   #43
Hey :-)
I too have problems with sub bass roll of. Changing the parrallel resistor at output from 47K to 1M fix the problem.
I use chokes from "Old stock audio" Portland, and 5MB OIP to output.
My amplifier load is about 10Kohm....
Cheers
Old 13th December 2012, 01:58 PM   #44
DF96 is offline DF96  England
10k||47k is 8.2456k. 10k||1M is 9.9010k. You are very unlikely to notice the difference.
Crossover Help Needed - bass rolloff wanted BobM Multi-Way 10 17th March 2011 05:24 PM
input bass rolloff, tilt and gain circuits? how to design them? rhythmdiy Chip Amps 5 27th October 2007 03:27 AM
12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) DougL Tubes / Valves 3 2nd August 2004 06:06 PM
how do I increase the bass in 12B4 pre-amp? up4 Tubes / Valves 10 16th October 2002 08:32 AM
Copyright 1999-2017 diyAudio
